short range locator
  • short range locator
    I'm looking to build a short range detector to locate small pieces of metal used as markers(around 2 x 10mm, prob. copper, but other metals considered) at a distance of at least 5cm, preferably up to 10cm. Can anyone advise on the most suitable type of design to use - induction balance or PI? Any suggestions regarding suitable circuits and coil designs?
    Thanks.
    Re: short range locator
    Not sure if I understand you correctly, but my PI detector with a Very Small coil, 1/2 in diameter should work ok. sensitivity can be reduced by lowering the gain of IC9 on my schematic.
    I assume you don't care about descrimination against some metals.
      PI, IB?????
      Too complicated by far.
      Look at the CS209 by ON Semiconductors. With a few extra components it works out at about $5 to make a 1/2 decent metal/proximity detector.
