HC11 SCI code
  • HC11 SCI code
    My name is Albert, now doing my project in my university. Currently doing the project of receiving and transmiting data from fpga to pc by using the hc11. In the project i need to
    1 - get the data from pc through rs-232 port. The pc part is done by my team mate. She using the Visual Basic to transmit a set of data .
    2 - the data then is receive by the hc11 and output the data to port B. The data need to be in 8 bits binary number.
    3 - after the fpga process the data the hc11 need to get the data and then send back to the to the pc and the data from fpga also in 8 bits binary number.
    Now i have the problem with this code can anyone help on this?
    BAUD EQU $2B
    SCCR1 EQU $2C
    SCCR2 EQU $2D
    SCDR EQU $2F
    RDRF EQU $20
    SCSR EQU $2E
    PORTB EQU $04
    ORG $00
    ONSCI LDX #$1000
    LDAA #$30
    STAA BAUD,X
    LDAA #$00
    STAA SCCR1,X
    LDAA #$0C
    STAA SCCR2,X
    SCIgetch LDX #$1000
    BRCLR SCSR,X RDRF SCIgetch
    LDAA SCDR,X
    STAA PORTB,X
    RTS
    ORG $fffe ;define the reset vector to point to
    FDB ONSCI ; the beginning of your code
    **** there are few question i want to ask??
    1. When i test this program using the simulator( THrsim11 ) i get the result what i get is in ASCII code. Is there anyway i can save the data in binary.
    2. Then i try to download to the M68HC11 EVB, i cannot download to it because having error.
    Because i need to get the data first so i need to get the reveiver code done before I can test the transmit and join it. I hope someone can help me...
    Thanks for it...
