VCO or not VCO ??
  • VCO or not VCO ??
    Hi all,
    I'm trying to find an answer on my question:
    does it better to use VCO or not VCO for using detector like PI hammerhead?
    As i 'm doing assembly of the CMS Hammerhead,i need to choose before make it: after it's will be difficult to change option!
    I'll be happy to have other sound for you about the VCO or not VCO option.
    I don't like that a detector sounds always with high level sound with no target so i think that no VCO will be better as it's only the level of the sound that is change liken to a VCO which have alway a high sound with the frequency change depends of présence of target.
    Thanks for your answer.
    PhilippeM
    yet question. inverting or uninverting OPamp is more preferable? TIA (-)
      Re: VCO or not VCO ??
      It's a matter of personal preference. I like VCO audio. Some people hate it.
      --Carl
        Re: yet question. inverting or uninverting OPamp is more preferable? TIA (-)
        Most designs use inverting. I removed this option from the latest PCBs.
        --Carl
          You can use both!
          I think, for human hearing (nicety), Vco is beter option.
          But You are right about tiresome constant level of treshold.
          In My detectors, I use combination of both.
          Salute,
          Jackdetect.
            HI all,
            Thanks for your reply: i'll try to assembly the VCO option . It will allow the security to heard if the detector is well tune as the sound is alway play.
            BYE BYE
            PhilippeM
              changed PCB image
              thanks Carl. here some variant, for DIY, 2 color GIF. done without permission, as I think you is in charge.
              yours
                thanks much Carl. what I would like see redrawing
                hi,
                I would like to order a PCB here, but I got a reply that GERBERs are not fitting.
                so I would like to enlarge dimensions of text, some lines and holes but I do not know how do it because did not work with GERBER files (mainly in ORCAD 7-9).
                yours sincerely
