Hi Eric,
I was get one of your Superscan on service.
First, I was found that monoflops gives more then one impulse, and replace it.
But after that, I was have lot of problems with instability of unit, and any adjust wasn’t help.
Finally, I was find that somebody (before my), probably in some copy process, was replace wires for 0V to other place, and provoke wild oscillations. So, I was formed central point of 0V on coil jacks, and oscillations was stopped, but still exist on low level. After adjust, units start works, and I can say that it is very good and sensitive detector. Of course, hi must be with about 10W of power consumption!
I still haven’t much experience with Pi detectors, and can you please help my with some questions?
After repairing, I was try that unit on my polygon, with his 50cm coil. In air tests, hi was fantastic, he fill iron plate 15cm x 15cm more then 1m.
In ground, also was good with brass, but big copper pan 35cm diameter 90cm deep in ground was fill unsatisfactory with lot of ground noise. Generally, with coil nearly to ground I always get strong positive response, and it is produce very questionable results. So, maybe I was miss something in adjust, or things are the same with all Pi units, which dictate work with coil about 20cm above ground?
What a function of 0ohm resistors?
Reducing of power is important with such power consumption, but it is waste of energy with serial transistor. Are you try reduction of power with PWM regulation?
Are you ever try to return energy from negative impulse, like in Minelab GP serie?
Thanks,
Jackdetect.
Thanks,
Jackdetect.
