Whats the coil diameter of the XR or Delta
  • Whats the coil diameter of the XR or Delta
    i want to learn the coil size-wire diameter etc. max. sensitivity for Delta or XR71 ?
    and i want to build 100mmx100mm coil ?
    Please help me
    Please help me
    100mm x 100mm or 100cm x 100cm
    if you want 100cm x 100cm then 16 or 17 turns is ok
      sorry xr coil size
      hi,
      i want to say 100cmx100cm. whats is the wire diameter ?
        The coil of 1 meter on 1 meter, 12 coils (about 50 meters) wires multicore, section 1 of mm, resistance there are more than 1.1 ohms.
        Bye.
          the damper resistor
          And how you calculate the damper resistor for this colis ???
          Thank
          nncunew@yahoo.com
            If somebody wants calculate it, perhaps to do it. It is rather complicated. He is faster considerably to match the suitable value. She should her be so, to transsient state after excluding current was located on the border of oscillation and aperiodical state. This is all.
            Mrand
