SWAPING TWO IC (LM 709)
  • SWAPING TWO IC (LM 709)
    At this moment i don't have the LM 709 IC, but i have the MAA 501, MAA 502 and MAA 503...
    Some body said me few months ago that this IC are equivalent.
    Is thuth ?????
    Have somebody the specifications of the MAA 50* in pdf or another format.
    Thank for all, and sorry for my bad english
    [email protected]
    LM 709
    See Proscan PI schematic here. The 709 can be replaced by the MAA501
    http://www.proscan.gliwice.pl/pi1.gif
      So good
      But i saw that the gain is very slow in this configuration.
      In others design is used more gains
      Maybe that MAA 501 is not exactly equivalent to LM 709.
      I make the cuestions for that i am making a design that use a LM 709 y i am using a MAA 501 but this circuits produce a oscilation of about 0.2 volts peak to peak an about 2 MHz. I mount the circuit in a protoboard, maybe this have relation with that problem.
      Thank,
      [email protected]
        replace NE 5534 :-)
          amtech2005
          Are you saying ne5534 is a substitute of maa501 or lm709??
            amtech2005
            are you saying ne5534 is a substitute for maa501 and lm709??
              Of those you listed the MAA503 has closer characteristics to the LM709.
                MAA 503
                But somebody have a pdf or other manual that show the caracteristics of this operationals.
                Thank, for everybody...
                I don't have 5534 i never have been saw this chip
                [email protected]
                  LM 318
                  And this op amp can be sustitute of lm709????
                  I saw the specifications of the LM318 op amp and this chips has very good feature.
                  thank
                  [email protected]
                    LM709 Direct Replacements!
                    nncunew;
                    What I do when I want to know what a part ### is to I just TYPE in the Number/Code into GOOGLE and then go to the Manufactures website and look at the datasheets there! Then I use the different Semiconductor Cross References listed Below to find Replacements on the different Manufactures websites. I have been able to find a Price Range on a LM725 of $2.50 to $12.00 each. Here are some resources that you may not know about.
                    http://www.national.com/pf/LM/LM709.html
                    LM709 Product Folder
                    Operational Amplifier [Obsolete]
                    See Also:
                    LM108 </pf/LM/LM108.html> - better precision
                    Send Off for Mouser Electronics Special Edition Vol. 1 2005 Semiconductor Catalog Library CD ROM. It contains the 1,532 page Mouser Catalog that is Searchable!!! It also has 131 other Searchable Catalogs for other Electronics on the CD ROM disk.
                    Also go to this website and use their Search Engines for Direct replacement parts. http://www.moyerelectronics.com/
                    The ECG and SK search engines can be downloaded and installed on your harddisk.
                    ECG909 is a direct replacement to the LM709
                    SK9177 is a direct replacement to the LM709
                    This Website has Search Engines for Semiconductor Replacements and WebLinks to the DATA Sheets for SAME.
                    Here is the NTE Replacement Search engine!http://nte01.nteinc.com/nte/NTExRefS...earch?OpenForm
                    I hope this helps you out!
                    Sincerely
                    Bill Adams
                      Here is another one I forgot to include above.
                      http://focus-webapps.ti.com/analog/d...+OT+hdr_s_xref
                        Largesarge,
                        Sorry, I beg to differ...One hundred And One ;-P
