Differential 8 shape config any suggestions
  • Differential 8 shape config any suggestions
    Hello Friends,
    I had been visiting this forum in recent past to reach to the excellent inputs from MD gurus. Having worked on PI detectors I decided to start with VLF detectors.
    I made a 12” TX coil and an 8 shaped differential RX coil size 8, processing I used in following way: RX coil -> Instrumentation
    Amp -> Sampling -> Integrator -> Low Pass Filter -> DC Offset removal -> DC Amp. I have sampled both the RX channels independently from which I get 2 different signals from each half of the coil.
    When I put metal on D1 (i.e. first part of the of the RX coil) it goes +ve and D2(i.e. other half of the coil) goes –ve this is as expected but the problem that I am facing is that when I remove metal from the D1 the signal at D2 rises which is detected by the A/D circuit and I get detection alarm at this stage also .
    Therefore in this config I get 2 peaks in detection one when I bring metal close to D1 and other when I remove metal from D1. I know principally there is nothing wrong in this behavior, but I need to know how I can overcome this problem so that detector works successfully. I would really be obliged to the valuable suggestions provided.
    Another thing I wanted to know I that what are the advantages of this coil configuration or is there any better coil configuration possible as my priority is max depth and ability to pinpoint the target.
    Errr... some drawings might help.
