PI1000 pcb reverse engineered
  • PI1000 pcb reverse engineered
    Look for component values on the schematic
    Thanks friend
      Whites 1000 PCB - Geotech Forums (geotech1.com)
        I thank very much Pete Maynard again for the pics of the board in HR he shared. Some people do their HOME WORK perfectum.
          I traced from pic of foil side of pcb and top side, but now I can't find the pic of the foil side on my computer. KT315, you can put the photo of the foil side here? ​​
            load whole archive, open WHITES folder. then WHITES PI, you will see needed folder. delete all besides it.
            https://drive.google.com/file/d/1pNU...usp=drive_link
              Hi DBanner,
              thanks for the info. You did a great job!!! I also got once from KT315 the Whites archive. But inside there was no image of the top layer with out components. There was only one image of the top/component layer with assembled components on it. From that image it is impossible to trace the top layer like you did. So there must be another image somewhere floating around. Maybe you got the image from somewhere else?
              GeoMax
                when needed guy did open the topic with the subject i asked him in private messages to share pics of high definition
                on my email. he did agree. those files 3.5MB every. can not put them here. treasuremaster 1000 has all data to be built, now.
                  Hi kt315,
                  thanks for sharing your archive. Yes, there is enought data input to make a PI1000. The "PIDX PCB" files are sightly different to the PI1000. I have those images already for many years as well and cross checked them with all PI1000/PI2000/PI3000 schematics which are floating around the Internet. The schematic and the "PIDX PCB files" matches basically with the PI2000 and not with the PI1000. Actually even without pictures and only having the schematic diagram you can make a PI1000 detector. I was asking only for the image because of reference.
                  GeoMax
                    floating in GEOTECH1. i am just take them from the forum and put them back, sometimes. people is still not able to use SEARCH engine. that is.
                    yes, PI1000 PI2000 PI3000 all they are based on CD4017.
                      There are 2 components on the sprint file I posted which are not labeled. Believe it or not the 5 key on my keyboard doesn't work!
                      I know I had pics of both top and bottom side but now I can't find the bottom side pic because my hard drive said adios a while ago and so I lost the archive.
                        Thank you very much KT315 for sharing the file.
                          you are welcome. i hope people will share with me their info if they do not see it there.
