Hi everybody,
I remember that when I had my first homemade pulse induction (the mark stuart's pic controlled one) working some years ago I had problems with shielding the coil to avoid static charges (ground capaciatance) but then another big issue was with red-bricks (and not only red) that sometimes are present in field in small fragments.
I experienced a lot of response with the stuart pi coming from small bricks fragments e.g. say big as a cigarettes box that sound like a small gold ring and so I was really confused at first becouse of the hi-resistivity of ceramics and other artifacts respect to metallic targets of any kind.
Anyway, I investigate, also on other forums, the problem and found that it was maybe don't from eddy currents in the target but due to magnetic materials inclusions generated in a transformation due to the hi-temperature in ovens that create maghemite crystals on ematite crystals present in the brick matrix. I know the "hot rock" cause false signals but a brick or other ceramic material has generally a much lower content of magnetic grains.
Does anyone know if the original (commercial) goldscan IV suffer of false signals on bricks like other PIs ? Does anyone know how (if it is possible) to avoid false signals generation due to small ceramic fragments ?
Best regards,
Best regards,
