Goldscan IV : my proto works
  • Goldscan IV : my proto works
    Hi all,
    I've just finished working on sheet 3/3 part of the schematic , mounting all the stuff on a protoboard and then connecting to my power supply.
    It works !
    Or maybe seems, well I have a response using 1 euro coin at about 27 cm (at the moment):
    At max sens (now using 15 us delay)
    - 27 cm --> start to click (all metal mode)
    - about 20 --> vco goes in hundred hz freq
    - about 15 cm --> screams (loud and steady tone)
    coil used is (matching approx the schematic value)
    - 8'' (20cm) od
    - 28 turns of 0.375 enamelled copper wire (transformer like)
    - shield is conductive (aluminium) mylar film 35micron
    - cable is standard rg-58au
    - R= about 2.9 ohm L= (measured) 412uH
    -IRF740 little warm
    -circuit stabilize after about 5 minutes
    -used also jfets J112 instead of J113 --> not relevant differences
    -used NE5534AP instead of uA709 (metallic case) : relevant differencies
    It's all for now.
    Best regards,
    biggest greetings Max! can you speedy look attachment on a subject of mistakies? tia!
      gs4
      Hello good post!
      is the pcb on page 5 good,no errors?
      has someone built this?
      I see it is a thru hole board with SMT resistors on the back.am I correct?
      All help welcomed thankyou
      johnno
        Hi KT315,
        I'm still working on the protoboard version and also in making a thru hole PCB.
        Thanks for the useful file. I'm watching for mistakes. Untill now I found only the differences in the reset stage :
        - two sources of J113s to ground
        - the 470K resistors (motion and autoretune mod) just don't know why R50 should be 10K (seems to me R50 and R49 must be equal - 470K works well on my proto but I prefer motion type detector so I've used a switch to disconnect them both).
        and preamp substition (but now it's not the original gs4 here):
        - i make the same thing ne5534ap is a really good preamp here
        The PCB in the file seems smaller respect to the one I'm designing at now ( this guy -Alex- seems have done a really good reverse on GS-4 and new PCB design).
        I had problems with the supply stage (555 voltage doubler) becouse of the noise propagation on the pream section (I'm using NE5534 after a try on different uA709-metallic case revealed they are not really stable --> lot of drift). Think one can use 7660 instead of the old fashioned 70's 555/bjt design.
        Also, as indicated by yellow squares, capacitors must be mached in values, becouse of the simmetry of the circuit (I've measured a lot of them before found same values in less than 1% of nominal value). Then also I've used schottky diodes (BAT73) in the supply section and tried them on the timing stage: in supply they improve efficiency but there are no difference in timing stage commutation, now I have 1N4148 on timing that are OK.
        Also I've tested TL084 instead of TL064 : are the same in noise level , but more consumption. I think one can use a better LS404 (STmicro) or MC33079(motorola) to have the best here.
        I think also the 14.4 batt pack was not a good choice; here one could use maybe an LM2990T-12 (LDO -12 regulator) to use directly a lead acid type battery (say 12V nominal - 1.2 A/h or more) to improve battery life or to maximize peak current on the coil. But I never tested if it works really. Another choice could be a NIMh battery pack (say 15V - 2700ma/h) : I'll try it soon.
        In off mode one have the best results in air tests. When switching to GND-balance (all metal mode) performance loss is about 10-15 % in air.
        Sel 1 and Sel 2 seems to be operated only if needed and by an expert user to "say" if there is iron or other stuff: just GS4 is not really discriminating , so a big junk of iron, and actually also a simple 6cm nail, sounds loud in any case.
        The align and tuning procedure seems very tricky.
        Best regards,
          Hi KT315,
          Best regards,
            Hi KT315,
            Best regards,
              HI MAX
              HAVE YOU BUILD GOLDSCAN?HI WORK GOOD?
              CAN YOU HELP ME TO MAKE ONE?
              THANK YOU
              BEST REGARGES
              PIGEON
