deep detecting
    Hi Detectionman. Congratulation. If you have a signal (from tx to rc) at a distance of 10m then you have a theoretically depth of 5 meters. But don't play with discrimination. It is not possible at 2Box detectors. The frequency is fix (it work with the reflect signal), and phase shift the same and the only that changes is the time that needs the signal to go from tx to ground and after the reflection to the receiver. I can't see any way for discrimination. But maybe YOU ????
    My wishes
      hello
      you can see to this adress
      http://www.igkelectronics.com/metal_...PI807_KIT.html
      is a good deep detector . with three possibility kit . but no discrimination
      i have one for sale , if you are interressed contact me
      my wishes
        re
        with discrimination you have this one
        http://www.pulsediscriminator.com/
        but no tested by me , is a module interesting
        or you have the adonis detector who will leave soon
        http://www.titanium-system.com
        best regards
          The detector that you speak about is not a 2box but a Pulse inductor detector.
          But we are not interesting to buy a detector. We have hoby to construct a detector or to make it to work better .
            TO GEO:
            Not all of us have the expert electronics foundation to be able to construct a metal detector from just a schematic! But I would still like the experience of contructing one! So any KITs are greatly looked for and sought after! And any built kits are also sought after! Just my input! I'm mostly a vintage collector! THANKS JOE
              hi geo:
              these my signal of 10 mts is test only whit my sense multimeter, in sound this only si ear for my only to 8 mts in one tac tac progresive on zero
              you say to me, 10 mts is proportional to 5 mts deep in ground, ok these is true, only in objetives messure 3 x 3 mts ferrous, in one objetive 50 x 50 cms to 5 mts, in not possible, ???? i am detect not easy, one circule 50 cms, at 1.5 mts buried recently
              in discrimination my idea is for filtering and notch the micro signal of reciver , i am not expert in electronic, my works is liric, in developments on proff and error, other posibilityes is one tx signal modulated special frecuencia mixed, and detectar whit rx , these is most difficultous, i am investigations at future
              apoligies for my bad" english
              detectoman
                XL PRO with 25 inch coil
                XL PRO with 25 inch coil will go 4 foot AND DEEEEPER.
