TESORO GOLDEN SABRE
  • Originally posted by 1843 View Post
    Hi Darko,
    Sorry, I have only the schematic.
    Regards!
    Well, then I'll try to design one just for testing, when got some time for that. I think Royal quite similar with TGS and this sholdn't be hard to realize . I hope it is worth to see advantage of this machine. Thanks anyway.
    Darko
    • Ok. Thanx ya all for stuff U advices me 4, especialy GEO & MAX. I order some parts and i'll pick them up in 2 days. Till' then so' long
      • Originally posted by Darko View Post
        Darko
        Why?
        Don't waste your time... As Max said, it is not as goog as Goldensabre...
        Kind regards,
        1843
          Darko
          if you wanna try royal sabre you can do with a bit more of efforts and goodwill.
          Me personally think that's somehow not good cause, as also ApBerg said, it's ,more complicated and don't give real big improvements.
          About depth it will be about the same of TGS if right optimized: oscillator is the same, rx preamp is about the same, integrators are similar etc... same power and same circuit and parts mean about same depth.
          The real advantages are the pinpointing mode and the "two-tones-id", though a bit complex to use cause one must take care of notch pot setting to have that target id working good.
          I'd like to test the pinpoint mod I've posted on my TGS but unfortunately I can't at now... cause I need it up and running and cannot dismantle again. I'm sure that changing all-metal mode to non-motion and adding retune the TGS will act just like royal in pinpointing mode... and only loss will be the 2-tones disc... that personally I think is not so good implemented that way.
          TGS is already a very nice machine and very similar to royal and others... but the big advantage to me is the simple implementation... much more simple than e.g. toltec100 or royal... making e.g. a pcb for toltec100 will be a real challenge for anyone cause of really huge and messy circuit.
          Best regards,
          • Hi,
            is discontinued dual channel BW 15MHz scope... (of great brand)...if in good conditions and working it's just right what you need here to see all stuff on the screen.
            Don't know if 100usd is good price for it anyway... but if is in good shape think that could be fine.
            Kind regards,
            __________________
            ...now this red cap gets a rap from these critics
            max: veryyyyyyyyyyyyyyyyyyyyyyyyyyyy thanks to you, this scope work fine, is sufficient good, for my, how you say, i am not expert in this stuff, but quickly learn, for my is not problem, i am very reary, i am some children whit new toy, jejejeje,
            i echange one man, this oscilloscope, for others electrics wood tools total of cost 100
            usd, thaks for your patiente and amability whit us
            jjejejjee apologies for bad english
            best regards for you and family
            detectoman mexico bayyyyyyyyyyyyyyyyyyyyyyyyy
            • This two tone target ID was interesting for me but I think now, I will all of my attention point to finish repairing my TGS. Thank you Max, and thank you 1843.
              Darko
              • Avatar
                Hi Detectoman,
                How about this for your avatar?
                • Originally posted by ApBerg View Post
                  Hello Frends.
                  The Royal Sabre is not the same as the golden pcb.
                  Think it is not a good project to make !!
                  Keep it simple.....
                  Best regards.
                  Ap
                  ApBerg, friend, can you post top/bottom scan or print of this pcb?
                  Winter is coming, i would have more than enough time to experiment....I would like to make this also...If it is possible...
                  Many thanks in advance!
                  Best regards!
                    Best regards!
                    yes winter is coming... also now rains too much for my taste...and I cannot use my assembled TGS ...I've reduced total weight to 1,45Kg now... and is light and comfortable...as never before.
                    Do you think the royal is worth a try ? Cause of dual-tone id ?
                    To me is complex enough and with just so few improvements to discourage further experimenting with... but of course, you can find it good for new experiences about VLFs.
                    I think that Lobo is a good new candidate... and at same complexity level of tgs.
                    I think instead that the toltec100 is much more interesting...say an order of magnitude more... but the schematics is so complicated that I give up with it from start... it's not an easy or even "normal" DIY project!
                    What's truly interesting in toltec100 is the multiple-tone-id and also the meter id... but I think it's one of the most difficault projects here one can try... much like e.g. CZ-5 or Goldscan: real challenge and just for experts.
                    What do you think about that?
                    Best regards,
                    • qiaozhi
                      gulp
                      who is these?
                      where you sacastes ese, mira pues, is brother of superman? edition european
                      ohh nouuuuuu
                      i am very beauty what this
                      un abrazo para usted qui----- fiuuuuuuuuuuuuuuuuuu
                      detectoman, the detectorist non plus
                      • ahhhhhhhh ok very good, this day i have one oscilloscope, ohhhhh,
                        but.....
                        ........ how i drive this stuff...??????? panel is some control instuments of cabine of transborder spacial columbus
                        buaaaaaaaaaaaaaaaaaaaaaaa
                        ok relax relax little tecnic
                        say me what i can t move whitout riskkkkkkkkkkk of short burn circuit???????
                        mammmmmmmmmmm
                        thanks detectoman
                        • Originally posted by detectoman View Post
                          qiaozhi
                          gulp
                          who is these?
                          ohh nouuuuuu
                          Hi Detectoman,
                          I'm not sure what you said - but it's a good avatar, don't you think?
                          Yes - looks like SuperMan's cousin. You can use it like this ->
                          • Max, i reduced weight of my TGSL to 2.2kg...
                            I dont know...? I do not bother myself with device complexity, never. Usually main reason to build or not to build some device is if i have good pcb for it or not.... If i had pcb draws i would make any good detector by now....My main problem are pcb's and (eventually) som rare component, hard to find in shops....
                            Lobo...? If pcb draw exist for it...i will make it for sure...Long winter here in mountains....nothing to do
                            Usually i am hyperactive, i dont sit at home 4-5 hours daily...but now...damn rain!
                            Max... i'll send you pm now...
                            Regards!
                              but.....
                              mammmmmmmmmmm
                              thanks detectoman
                              Hi detectoman,
                              thanks for greetings I wanna reply with mine too.
                              About scope you can find informations in spanish on oscilloscope (general) at:
                              http://es.wikipedia.org/wiki/Osciloscopio
                              and a small but good tutorial (in spanish too) on the hameg's website at:
                              http://www.hameg.es/osc/osc.htm
                              that's more than enoygh to start understanding how it works and how you can use it.
                              It's a really powerful instrument if you can use it right... and so I think you'll be fine after a while using it with success.
                              Enjoy !
                              Kind regards,
                              • Elie
                                ahhhhhhhh ok very good, this day ohhhhh,
                                but.....
                                ........ how i drive this stuff..buaaaaaaaaaaaaaaaaaaaaaaa
                                ok relax relax little move whitout riskkkkkkkkkkk... burn
                                mammmmmmmmmmm
                                thanks
                                I think Elie was on top of detectoman today on bed, oh what an expressions
