TESORO GOLDEN SABRE
    "When you look at circuit, you wonder: why is audio proportional? Comparators U106 make a binary signal, original signal amplitude is forgotten -- right?."
    No, it isn't. In theory any comparator has a binary output (+Vcc or -Vee) but it really isn't on practice: simply doesn't exist a comparator that give output at 2 discrete levels of voltage... not considering also that you have also output stage voltage drop... in real devices.
    What happens really: you have an op amp that works in open loop at highest possible gain... that is similar in behaviour to an ideal comparator ...that doesn't mean you have really, always 2 discrete levels at output and no intermediate voltage.
    When you consider gain you have the answer: consider +8 and -8V as supply voltages and open loop gain of 200000 (as typ of lm393)... how much differential input voltage is required to saturate device ?
    deltaV+ = +8/200000 = +40uV
    deltaV- = -8/200000 = -40uV
    So... you have full saturation voltages out the interval +40 to -40uV at differential inputs.
    But what you'll get inside the interval, what if you have e.g. +10uV there ?
    V=10uV --> Vout = +10uV*200000= +2V
    +2V , not +8 or -8V... so it's an "intermediate" voltage out of discrete limits.
    Why I'm doing all this ? Simple... you actually HAVE 10uV and similar voltages there... expecially when you'll measure submicrovolt influence of a small coin at 30cm from coil bottom! So you'll get not full saturation at comparators... but intermediate values and then (sadly) intermediate sound... cracks.
    So, when you consider solid signals... like coins at 15cm... you'll get full sound... and real saturation of device, but on weak signals you have linear amplification and intermediate values, thus resulting in poor sound.
    This explains why the audio on TGS is proportional... after a particular depth/size combination... so input level threshold... the device will give you a proportional tone related to weakness of signal or the far/small target.
    Kind regards,
    Interesting point, I not even imagine operate in linear region! But wait -- I would think noise at that stage is greater than linear region anyway. Any signal small enough to be in linear region totally swamped by noise. Yes, we adjust sensitivity control to be above noise, and deep coin could move signal into linear region, but the noise would come with it. I think very low probability it stay in linear region because of noise -- but I'm just guessing!. But still you are right because it all adds up and linear region is less volts for sure.
    I will keep it in mind for design experiments.
    But pulse width very important too -- I keep watching signal from comparitors on scope, very low sweep. If disconnect output from rest of circuit, pulses very square (binary), even skinny ones.
    Reconnect, and pulse leading edge rounded off by capacitor (trailing edge still sharp, as predicted). Very quick pulse never rise too high, less voltage. That is good I think - makes "chatter" pulses quieter. Maybe that is why trailing edge designed to drop fast, so many chatter pulses will not combine into one big false pulse.
    This makes me think: maybe improvement if leading edge rises even slower so skinny chatter rejected even more -- increase C25 and increase R40? Just something more to play with, even though Tesoro is always right! (but they must design for mass production, we can tune.
    • 1. Schematic from "Gift Pack" shows R47, R55 on output of last LM393 comparators, but other schematics do not have. They must affect audio I think, but has anyone tested?
      I tested those already. I havent spotted any difference than.
      I'm playing with those resistor, at first thought: make bigger, stretch pulse, make trailing edge slow... but now I think, no, that will increase false signals from chatter by allowing many pulses to combine. However, still may be good idea because deep coins may combine with noise and make "stutter" signal, so good to combine in that case! It depends on how much noise is around.
      No. I reffered plug thing in situation ONLY when plug exist,connected in setup but speaker is used. Cracks appeared on speaker - not on ears?? Funny and strange? Once plug removed - speaker sounds perfectly!? Funny!?
      That is spooky! I would think it is that little spring connector that makes contact when you pull out earphone plug -- maybe metal-on-metal you made a diode! I wonder if speaker noise (or magnet) is vibrating the contact.
      What bias?
      Just resistor adds to emitter-follower, increases impedance at base, less drag on input signal - kooky thought.
      Ha! I have idea for you; try to locate and remove 1M resistor parallel to diode at last stage! (if there is any 1M resistor there in Compadre). Than you will get same audio as on TGSL.
      Hey, nice idea -- when I get the b--ls to cut into it!
      This is what i thought also. I experimented with R45....no significant differences....sheeeeeshh! That's why i suggested extra amplification, in my last post...
      I think careful design with pulse shape going into LM358 will be the answer, whatever it is.
      When I look at design I think most detections will make same volume, only very, very deep coins at edge of detection will be quieter, so I think maybe really is not proportional audio design in general.
      Also, threshold for LM358 U1007A is very awkward design for me, I am struggling with it, won't obey me or make mods easy. Everything is relative near negative rail, very awkward, but I think I need to fix something too.
      You will have it in no time. Just do a proper pcb.
      I will be excited to do it, your encouragements very appreciated, you got it all rolling with excellent PCBs! I study and appreciate layout even more, you kept "Sync Detector" drive signals nicely away from sensitive areas. I'm not good with PCBs or chemicals (or spending money), so my first try will probably be transfer to copper board from printer, then dremel to cut away copper between wires -- more craziness. But I amuse myself...
      • Don't want to spoil the discussion, though the page is already going to end..
        here are some images from today
        1. the sweet ICs im going to use 2. bottom layer with gnd plane 3.time to solder
          Those are most beautiful!
          I'm very interested in effect of ground plane, what you find.
          • nulling and RX connections
            I saw Max advice on RX coil phasing and nulling, 200 deg, etc, but now I have some more confusion.
            I use my "nulling machine" for experiment (what, you never saw it yet? Here's a good laugh, see pictures).
            Using screw, I adjust my coil to get a good null (less than 2 mv signal, just noise left, see first oscilloscope picture. Top trace is TX signal at collector, 5v/div, bottom trace is RX coil by itself, 5mv/div. Coils are grounded together with shield wire.)
            Now I connect coil to circuit -- not sure which way, just pick one.
            Then I look like Max says at pin7 of LF353 and compare to TX signal. See next picture (top trace TX, bottom pin7 20 mv/div). Phase is less than 90 deg looks like.
            Now I adjust null of coil teeny, tiny, bit, just breath on it, go slightly to other side of null. See picture, phase completely shift, like turn upside down.
            You already know this -- when right at null center, very slight shift either side makes huge phase difference. That must be why someone says don't null exactly, go more to one side.
            So now I'm not sure which way to connect RX coil leads to circuit. I think we need total explanation starting at coils.
            First, which leads are shielded and connected together, based on direction of windings. Then, which pin on ciruit gets shielded lead. Then, using Max's advice for 200 deg phase shift, we can decide which side of null to adjust coil on.
            I think it's been said but in pieces; if someone could go start to finish it would be good reference.
            Thanks!
            P.S. More pics next post...
            • More Pics
              Continued...
              Pic 1 - one side of null.
              Pic 2 - other side of null.
              Cheers!
              • Eclipse i envy you on LT1008 !!!
                Ha,ha...if only i could find those in local shops! I am sure LT1008 would be much better there at TGSL than LM308!
                What a nice pcb!!! I envy also on that! You are the artist! Bravo!
                Most beautifull pcb i saw so far. Excell job! Bravo!
                And Simon... i envy you on "nulling machine" and scope !
                Ok...today and tomorrow i am stuck repairing TS800 and TS1000 coils for Musketeer. Day after tomorrow i will return to TGSL .
                The hell with Minelab cables there! Both cables are "munched" in several places...like rats did a job!
                So low profile cables? I dont beleive my eyes!?
                I have Relic Hawk coil with extra high quality cable. What happened with Minelab latelly? Are those latest produced in China?
                Although this is a way off topic i would give you a short and valueable hint;
                TS800 and TS1000 are having exactly the same inductances and pretty close resistances as my 39cm coil for Relic Hawk. So....
                Conclusion; those could be succesfully used with Relic Hawk and vice-versa, 39cm RH coil can be used with Musketeer's.
                One more thing; connections in connector must be corrected.Pay attention on that. Those jokers from Minelab intentionally used different connections in conectors for RH and Musketeer, so laic user can not dig out this hot and sweet secret!!!
                You own me for this hint!
                • Hi Simon,
                  you have an excellent nulling machine! Really intelligent solution.
                  I am using two component epoxy glue. If the nulling wasn't good, then ripping the coils off and trying again and again...
                  Aziz
                    Hi Simon,
                    Aziz
                    I'm like woman, need to change mind all the time, so do anything to avoid solder or glue!!!! (just kidding, old joke about women, shame on me)
                    Tektronix 465 - bought it new full price with first paychecks of first job -- better than food! Don't look up when it was made -- but I feel like I'm 22 too...
                    Cheers,
                    • Hi! ALL
                      I'm starting the TGSL with the new audio improvements by IVCONIC. For that I redraw the TGSL PCB.
                      I intend to make a 25 cm DD coil with graphite shielding for this project.
                      DIRCEU
                        very good work!
                        It's really good made PCB, did you use a professional service to get them or it's your work only ?
                        The components seems very good to me for the purpose.
                        It's really probable you'll get improved S/N from that approach.
                        Nice to hear good results!
                        Kind regards,
                          Continued...
                          Cheers!
                          this is the right side... if you're looking at output of preamp: there's something (I cannot read it well from picture) around 200°
                          That's where you're supposed to "null" the coil: be aware you'll probably cannot mantain that phase also at minimum voltage... you just need to keep voltage smallest as possible matching that phase... other phase will false disc and geb... and your device will be completely unreliable.
                          Kind regards,
                          • for Simon
                            look at that: it's Qiaozhi's picture of signals at TX, RX (output of preamp) using an original coil (maybe it's an 8'' round ? I've tested an 8'' round an was exactly the same stuff too...I suppose they are about all the same... no matter of size or widescan...spider... etc).
                            I read about the same on my 9x8'', also... you'll get left shifts of RX signal nearing any metal, but no shift in pure mineral response (e.g. ferrite crystals)
                            Kind regards,
                            • Hi,
                              simonbaker.
                              This is a nice idea for experimental nulling.But I dont see how you can fix the coil in its final position.You see my point.I also hate solder and desolder again but......This are not even shielded.Plus I think that the both windings should be sealed with epoxy at once.And thats the trick.Keeping good null in same time.
                              I had some average experiance with sealing step buy step.Several layers.
                              So the windings should be fixed reliable and then sealed at once with epoxy.This way you have net and resistable construction.
                              Dirceu.
                              Nice work.
                              Eclipse
                              You lift the standarts here.Where you order this PCB and the parts.
                              Please post about LT1008 performance.
                              • Given the above published photos have the following question:
                                What exactly is the method of calculating phase difference between TX and RX with two channel analog oscilloscope, so the result is in degrees?
