TESORO GOLDEN SABRE
  • Dear Max Ivco Qiaozhe and all
    my TGSL is ugly!
    Please help!
      i need somebody to annoy and bash always!
      Please help!
        Damn, I'm sorry, I was not neat enough... made mistake labeling R13 in schematic.
        Here is fixed version; I don't know how to make PDF (excellent image compression!!! What program???).
        Since purpose is exactness, I guess we should update with this...
        Hi Ivconic,
        Please can you convert this to PDF?
        I would prefer if you do the changes, as it's your work.
        Then I will update the info on Geotech.
        • Originally posted by peroon View Post
          my TGSL is ugly!
          Please help!
          What happened to the good old days....
            Hi Ivconic,
            (Thanks Qiaozhi -- looks like it avoids "pollution" by permanent file area where we can update without creating new attachment, keep people happy...)
              Hi Ivconic,
              Would be better if original .sch file is posted here. Jpg with such huge resolution will produce also huge .pdf file.
              Post here ExpressSch .sch file and i will put it in small .pdf ...
                Here it is...
                thanks
                  • TGSL
                    So what?.... So you are now having splendid knives&tubes detector! What's the problem?
                    Dear Ivconic
                    the problem is i cannot reject ointmet tube and knives!!!
                    TGSL this time very stable only chatter from time to time
                    and i can reject pliser nail pulltab totaly only problem with ointmet tube and knives any suggestions please.
                    another problem is i am using a 8cm long ferreit from Radio antenna it dos reject it totaly around 5cm but abit lower it sound i mean about 2,3,4cm
                    kind regrads
                    • Originally posted by metaldetector107 View Post
                      Dear Ivconic
                      kind regrads
                      Dont worry about "knives and tubes". Knives are usually made from steel - tought to be rejected, especially if those are massive. Oinment tubes are usually made from pure Al (thicker walls)- not possible to be rejected. So stop worrying about that.
                      8cm long ferrite rod makes sounds at 2,3,4cms..... obvious proof that your coil is not balanced well. Put more effort in balancing coil. Make another coil. What can i say? I can not help you here!? No such advice which will solve your problems remotelly. How to help? Help yourself by better understanding and involving more effort arround coil..
                      Regards!
                      • Ok...metaldetector107;
                        here is what i want you to do!
                        Disconnect ONLY RX wires from your detector and connect those on digital multimeter. Switch multimeter to AC~200mV range. Switch ON detector. And measure residual voltage. Than post here.
                        See on posted sketch bellow, it is how should be done.
                        Post what you measured here and we will see what to do... OK?
                        • Hello
                          [fdghfdhdfhfdhfdhfdhhghdfh
                          • Wow! You dont say!?
                            • TGSL
                              Dear Ivconic
                              i know what you mean actually i put digital meter on 200m
                              and it read 00.6 i can make it lower to zero even but zero is not very good
                              kind regrads
                              • TGSL Complete Details
                                Version 3.0 posted here -> http://www.geotech1.com/forums/showthread.php?t=15710
