TESORO GOLDEN SABRE
  • EDIT!
    I forgot to attach the Edited PDF Version of the Placement OC.pdf file (named: Placement OC (Edited).pdf). This file has compatible circumference to the PCB.pdf file, and has now been added as attachment together with the original version from @Ivconic as comparison.
    I apologize for this mishap!
    Robert
    Placement OC (Edited).pdf = Edited Placement OC.pdf file (JPG example given below)
    Placement OC.pdf = Original version from @Ivconic
    PCB.pdf = Original version from @Ivconic
    • Orderable parts list for TGSL
      One of the toughest parts of a project can be ordering all parts. Below is a list of parts that I used for my last TGSL project. Everything works as advertised. Parts match the layout above. The only exception would be that I used J107 for BF247C and TL071 for LM308.
      Don
      • Uploading attachments help!
        • TGSL - Datasheets of Components
          Uploading attachments indeed help!
          All Datasheets of Active Components used in the TGSL as described by @Ivconic in his compiled project (see link on previous page) are presented here as Attachment.
          Due to the fact that Board restrictions do not permit RAR-Part Files (or even RAR-Files), and also not ZIP-Files of more than 1MB in size, I had to pack the RAR-Part Files into separate ZIP-Files. But no worries here, for ZIP-Files can also be opened with WinRAR. What you will have to do is; put all 7 Files into one Folder, then "extract here" all selected ZIP-Files in one go, and then do the same with RAR-Part1 File.
          Voilà, a miracle has just occurred, and you did not even need Dowsing Rods to perform it
          Enjoy!
          Robert
          • Good work guys, much appreciated by all TGSL beginners. Would also be interesting to explore all the parts substitutions that will work reasonably well, this is a start.
            Maybe Qiaozhi can attach this to that TGS final thread/message he set up.
              As I was downloading this information, I was actually thinking it would be a good idea to add it to the TGSL final thread.
              I'll let you know when it's there!
              • It's there.
                Note new file type (rar) is now available.
                • Corrected one line.. U104 and U105 should be a TL071AN or LM308N.
                  Don
                    It's there.
                    @Qiaozhi,
                    Thank you very much, this is certainly a welcome addition to the boards Attachment Management
                    For those who are interested in PCB manufacturing done by the professionals, in the Quote Link --> given below, you will find the best reference in the field for over 30 years! An eBook with a whopping 1632 pages, including bookmarks in PDF-format.
                    Originally posted by Cyclonite View Post
                    Printed Circuits Handbook - 6th Edition - By Clyde F. Coombs (2008 )
                    The World's #1 Guide to Printed Circuit Boards, the best reference in the field for over 30 years!
                    Interesting however, is a small bug that does not allow an "8" to be proceeded by a ")"
                    Look what happens:
                    And now spaced, and there is no more smiley:
                    I also have found a few Treasure Hunting/Metal Detecting eBooks, ... but where should I put them ?
                    Robert
                      Don
                      Replaced parts list with modified version ->
                      http://www.geotech1.com/forums/showthread.php?t=15710
                      • Originally posted by Cyclonite View Post
                        Yes - I know about that one. The workaround is to simply to add a space between the "8" and the ")". The other solution is turn off support for smileys, and we don't want to do that.
                        • schema,layout files
                          Qiaozhi -- it would seem that the original Sprint layout and schematic file (.sch ExpressSCH format) should be bundled in the TGS project files; they can be useful for mods.
                          • 24k resistors
                            There are two 24k resistors used in the TGSL schematic. One is in the TX oscillator, the other is a pull-up for the discrim comparator driving a JFet detector.
                            Can 22k or 27k resistors be used just as well? Why did Tesoro choose 24k? Especially for the pull-up?
                            • TGSL Coil dimension
                              Hi fellows!
                              I want to build my own TGSL, following Ivconic's tutorial.
                              I am not sure about the dimension of the coil, so before I start, I share my coil's plan. It is designed with autocad, and this is a printable pdf version in 1:1. Please comment it! If it is (or will be) a good construction feel free to use it, it is my gift.
                              • Reply
                                Originally posted by pip3c View Post
                                Hi fellows!
                                If this is ok, than thx your effort, I will use it sure.
