TESORO GOLDEN SABRE
  • Hi
    Nice build,
    All you need to do now is install the electronics into a metal housing make sure there is good bonding from earth to coil plug and pots and all should work well.
      Can i put This LCD To TGSL-Edu
      If Can, How To Connect it
      if any one have tutorial about how to put this LCD to TGSL-Edu Can You Share Here!
      • VDI LCD 2x16
        Originally posted by paku View Post
        [ATTACH=CONFIG]24487[/ATTACH]
        VDI GEOTCH
          i need help how to wire this potentionmeter on this P10 P20 P30 is that right or not on my picture
          • That is correct. This is the discrimination potentiometer.
            • Ok thanks and what is K1 K2 K3
              • K1, K2, K3, is the switch to the Disc and All Metal modes. K1 and K3 are connected to pins on the switch side, and K2 is connected to the central pin of the switch.
                • Ok thanks master
                  • Originally posted by paku View Post
                    Discrimination switch connection point
                    • What Is The Best Speaker For TGSL-EDU
                      i buy TGSL from silverdog but it just beep speaker
                      so i want change it what is the best recommendation From Guru-Guru In Here
                      • 4-----8 Ohms
                        0,5---1W
                        • i want put the mainboard to my box so i need use metal box or plastic box
                          • I recommend metal box.
Name:	newpcbf-1024x768 - Copy - Copy.jpg
                              Why This IC is Hot And I Get Only Sound Very Speed Beep
                              or i get rong on my coil conection
                              • The LM308 can be damaged, or placed upside down. Try a new IC. Before turning on the detector, the coils must be connected. You have to measure the voltage 8V and 6.2 V. Greetings.
