TESORO GOLDEN SABRE
  • Originally posted by amarasha View Post
    hello
    please help me.
    i made this tgsl and work well all metal but disk mode not work. -5v on schematic is -6.2v!
    what can i do to improve that?
    The voltage is normal, no problem there.
    Try reading TGSL Troubleshooting threads for help troubleshooting. Requires oscilloscope and good understanding of the circuit.
    • ?Please anyone who got the Board layout in black and white sides of the top and bottom of TGSL silverdog version
      • Qiaozhi
        how can i nulling coil & how i must put cap on coil?
        please show with picture
        thanks
        • Originally posted by alonejax View Post
          Qiaozhi
          thanks
          All the details of how to build the TGSL design are in the link above.
          • ok bro
            but i think we can better field coil ; isn't right?
            can you help me please?
            i think if we put more gap in field of coil ; coil have more power and sens more
            do you agree my freind ?
              ok bro
              If you increase the coil overlap you will upset the balance, and the phase-offset will be incorrect. This will result in the ground balance and discrimination not working properly. Coil building and balancing is a complex subject that would take a whole book to explain.
              • special thanks Qiaozhi
                i have two questions
                1) in all metal mode of tgsl , what's maximum sense in ground for example a hammer?
                2) i want a good and strong Replacing for this part ; cd4538 & cd4066 & tl062 , use in delta puls
                thanks again for replay..
                • i want replace bc546 & bc557 in delta puls with best teransistor
                  any body can help me please ?
                  Dear Qiaozhi , i decide build pi detector Because i understand vlf detector can't detect more than pi detector
                  can you Introduction me a good pi detector for small & medium metal in dept example for 2-3 meter please ?
                  you help me very much Hitherto , thanks a lot bro..
                  • Today i just want to say i have buy kit from silverdog is very dog and dog dog dog i have buy TGSL kit and IDX kit is just make me angry
                    when i make that farking TGSL its make many error so i stop it and try to make the IDX kit from silver dog dog dog and dog
                    when i finish make the farking IDX im still get many error on IDX kit from silver dog dog dog and dog
                    o when i check the schematic is not same on the circuit board is very like dog dog dog by theway thanks to send me the you can make money with your cheat board
                    • There is nothing wrong with the silverdog idx pcb .
                      I ordered one about a month ago and my idx works great.
                      Thank you silverdog!
                      • i have check the board on the electronic expert company on my country i bring the board and the schematic to them
                        then there ar check it for me i have pay for 50usd for check the TGSL
                        there ar telling me your board and you schematic is not same and other component is not same like on the schematic have error on the board
                        to fix the board i must pay for 100usd so now i think better i etching the new board
                        • ?Spike I guess tgsl and isgl can't be the detection of more than 15 cm I've created isgl cannot be more than 15 cm if it could reach 25 cm from the sensitive but also against the wave of his hand instead of colored metals. will you've ever made toll or delta PI detector poloneis ..??
                          • Originally posted by liekwang View Post
                            Have you tested your TGSL with a commercial Tesoro coil?
                            You should be able to get about 30cm on a large coin with a 9" coil.
                            If your hand is being detected, then you've not shielded the coil properly.
                            • ?Qiaozhi I don't wear a commercial coil I don't have paypal and his kind and would also be too expensive if shipped kenegara I get 3 or 4 orders of magnitude if you sign in to my kenegara then what is your suggestion for the time being I put coil diameter 28 cm for TX and RX 7omh 2, 46omh please give me an example to ISgl musketer thank you for your reply
                                For the IGSL Musketeer, you will have to ask someone else, such as Davor.
                                For the TGSL, all coil building details are here -> TGSL - Complete Details
                                Follow Ivconic's instructions exactly and you should end up with a good coil.
