TESORO GOLDEN SABRE
  • If co tuned its actually very stable, they jump into each others pockets and injection lock. They become unusable when you approach the ground with it. The Tx and Rx phases pull apart enough to false continuously. The Rx tanks phase response has a real steep gradient in this case.
    Peak one out and give it a try. Maybe it does work and Im making this **** up.
    This is what I said about - it dont work.
    • allright.. tgsl working. thanks everyone.. might not get the best depth but 25 26 cm is satisfying for now. i think i need to make better coil for that.
      next step vdi. can some one point me where to start? i think the vdi needs another thread coz too many pages to go through
      • HI ALL
        please what is the equivalent for J107?
        thank you
        • Originally posted by pigeon View Post
          HI ALL
          thank you
          BF 245
          • Originally posted by Toros View Post
            BF 245
            thank you verymuch
            • hi.. i need some advise.. if i want to use 2 9v batteries for tgsl, do i need to make any changes with the schematic? or can i justdirectly use them? can someone help. 8 pcs of AA battry takes a lot of space..
              • 8 pcs AA have 2500-2700 mA*h, 2 9V have 150-180 mA*h ---- >10X
                • owh, sorry that means it wont last long is it? thanks.. and sorry i am just a beginner..
                  • yes, that means. with 8 AA you will have a time on hunting more than 10 times vs 2x9V. this is the advantage.
                    • hi .. i i just got 3 li ion battery, each is 4.2v and 4200mah, anybody got battery chager circuit for this? i need to add this to my tgsl.
                      • The batteries you have are sometimes marked as 3.7 volts and sometimes it seems as 4.2 volts. But I believe they are 18650, check on the cell body for this number. If it is another number, ignore this post.
                        Then they are nominal 3.6 to 3.7 volts....
                        http://www.aliexpress.com/store/prod...223471732.html
                        These chargers are available EVERYWHERE!! ebay, internet, some shops and and and......
                        I hope this helps.
                        Andy
                        • Originally posted by sukri01 View Post
                          ko pg cari la charger nokia lama2 ko tgk la output dia berapa tu pun bleh pakai direct je
                          • Originally posted by paku View Post
                            • Hello. I need the data for coil of 36 or 39 cm. Diameter and windings?
                              • Hello,
                                Here is finally the TGSL functioning properly. Very diffcult to achieve a proper coil.
                                Dicrimination works fine
                                impeccable GB
                                Test in air:
                                https://www.youtube.com/watch?v=Zu7G7DSoCXE
                                I am testing in the earth:
                                50cent euro is taken by TGSL at 20 cm and I compared with the Goldmaxx power who also takes limit.
                                I noticed that the TGSL must be swept slowly to make the target.
                                I would now improved sensitivity because I noticed the potentiometer varies very little
                                have you some tips to make measurements of sensitivity and improved?
