TESORO GOLDEN SABRE
  • Max, as I can see you discover the tantalium cap. You make an announce like this:
    "See the tantalium" Great!
    Esteban's return
    • Oh a great surprise! Welcome my friend!
      Max, regarding C64, maybe your memory is in the level of the Commodore 64.
      • Originally posted by Esteban View Post
        Esteban's return
        Hi Esteban,
        yes I discovered when was 9.
        Maybe you don't know what is it... cause you have no education in electronics... what you say ?
        Oh you have a downloaded from Internet Diploma!
        You know I'm not an educated person like you are.
        So when Nihil call you come ???
        What a man !
        C'mon wanna see all the clan here: all the LRL-tribe.
        Seems my argumentation irritate people like you Esteban , but why ???
        Maybe are you the master at Mineoro ???
        Kind regards,
        • Originally posted by Nihil Roma Maius View Post
          Oh yeah, big surprise !
          Same people...same games...
          Maybe same person ???
          Nihil = ESTEBAN ???
          Esteban I like you cause you are a real joker!
          Best regards,
            "Max, regarding C64, maybe your memory is in the level of the Commodore 64."
            Is this an insult ??? Have to call the ADMIN ???
            JUSTICE COME !
            BS and insults to who says the sad truth ! Here is the recipe of the LRL-tribe!
            Good luck,
            Esteban ops Nihil
            • But don't ask me to explain you what's a C64!
              This is an indirect insult.
              • Sr. Esteban, es bueno verte volver aquí. Todos te necesitamos para balancear la opinión del LRL.
                Recuerdos,
                J_P
                • Hola J_Player
                  Gracias. Thanks very much!
                  Esteban
                  • Hi Max. Today i discover a big problem on my GS circuit. The 15nF cap on the RX coil connection, it wasn´t a 15 nF cap . it was a 10pF cap. I think that my eyes didn´t note this when i assembled GS. So this afternoon i replace it with the correct 15nF cap, and now with my first coil that i build, i can get much much better than ACE 250. 1 cm coin is detected on free space at 24 cms.
                    Now discrimination is working much much better than before, excellent. No noices, no hum, very stable. All functions are working very stable too.
                    Tomorrow i ll try it on the field and after that i ll finish the 22 cms coil to see how this pupy can perform.
                    So you people that are no shure if replacement parts can work on this MD, don´t worry, it will work, so go ahead and give it a try.
                    Thanks Max and all good friends for helpping me to finish my MD with success.
                    Best regards
                    Nelson
                    PD: all my test will be posted later.
                      Best regards
                      Nelson
                      Hi Nelson,
                      congratulations: I'm happy cause your detector is working better now.
                      Yes, the TL081 would be Ok, also in analog crossref tables is indicated as direct LM308 replacement.
                      Also other parts are OK.
                      Kind regards,
                        Hola J_Player
                        Esteban
                        Hi Esteban,
                        but what's that gun you're toting ?
                        Kind regards,
                          Big problem is that I need lot of solvents/chemicals to remove "well" any flux.
                          How do you remove flux ?
                          Best regards,
                          For what a lot of solvents/chemicals for a easy solution? Do you want explode when you light your Clint E. cigarr? Simple (now you know and the thanks is real): isopropilic.
                          As I see you don't know how. Maybe you use the alcohol for other purposes, but no for to clean PCBs. When you want to write here and in LRL section, please leave far the alcohol!
                          ALCO-COOL
                          Found another mistake on schematic: tantalium cap reversed!
                          Ah! But not in your PCB?
                          Have to find some spare time!!!
                          Best regards,
                          Also check your PCB.
                          You have much time, but use for build good coils.
                          Reality ??? Reality is that you want present yourself here as an educated, rational mind but the truth is that you support nonsense.
                          My education said me that I'll be educated here and in other parts. So, do you're educated here and bad-educated in other instances? If I post in LRL section, I am no-educated, but you are, OK? Justice, where you are?
                          I'm on the way...
                          And so what?
                          PS: do you see the RED tantalium cap ?
                          And...??? Great!!! As I see, is the first time you use this type of cap.
                          Respond, please!
                          As your buddy RObert? He use various masks and you said nothing. Justice, come, please!
                          Do you deffend RObert? With this kind of friend (you) RObert no need enemies!
                          Do you scare in via to emit your opinion against administrator's decission?
                          ... find funny many things I read in the LRL section
                          Yes, and I'll dissect your inputs in LRL section in via for to demonstrates your funny non-senses.
                          Guys, take care.
                          I wrote:
                          "PS: do you see the RED tantalium cap ?" (but just to say "Hey I have have it not electrolitic guys!" )
                          Then you wrote:
                          "And...??? Great!!! As I see, is the first time you use this type of cap. "
                          Is this a direct insult ????
                          Oh yeah, I have no credit here... CAUSE I SUPPORT CRAPPY-LRLs, sure!
                          JUSTICE COME!
                          Find another argumentation... THE PLUSH-DOLL ??? What do you think ???
                          Oh, too complex topic... I see! Maybe we can talk about popeye's comics and sparks in dog BS ??? What do you think ???
                          C'MON LETS WIN THE CHALLENGE!
                          I'M AWAITING
                          Best regards,
                          • Hi
                            Max.
                            Can I compensate this low resistanse somehow?
                            Whith change of caps or something else?
                            I have no wire left!For now!
                            Mybe a few turns!I can try to add them?But will be hard and ugly!@
                              Max.
                              Hi tiktak,
                              sorry, you can't. If is something 1 or 2 ohm less no problem I think (so something 16 or 17 ohms). But if less probably your oscillator wouldn't be happy, and even having oscillations you could get too far frequency if turns aren't enough to math expected inductance.
                              I've tested my PCB and got 14.35 Khz that, if I remember well, is the expected frequency for GSabre.
                              Best regards,
                              Try it... if doesn't work
                              • Hi
                                resistance=18,5 for both!
                                I think this should be enough!
                                But.....
