TESORO GOLDEN SABRE
  • I have strange TX graph ... it is cut off
Name:	tx-rx on connector.JPG
    TX is cut off, RX is one sine wave.
    Maybe it is not adjusted with board or ...
    • Originally posted by sdesic View Post
      It is OK to know that if I get one of those coils cheap.
      15nF can be changed to 10nF or less
      How do I calculate that value ?
      http://www.lautsprechershop.de/index...hwingkreis.htm
      http://www.do2jmg.de/article.php?sho...reis_%20online
      attention chosse for lc circuit if caps are parallel or in serie
      • Originally posted by Silver Dollar View Post
        Coils can go any which way just swap the leads on RX if you get a double beep.
        It's better for RX to be nearer to the ground (for better signal pickup).
        For less noise it would be better if the outer wires were towards electrical ground.
        I use this calculator to find cap values;
        http://www.siversima.com/rf-calculat...FfB3cAodsAgAzg
        hi all does any one have a multi input calculator, like this one but so it will give cap values, if you know the freq and inductance.
          Are you shure it is gold?
          Can you try gold coin?
          Rings are difficult...
          i dont have gold coin bro i just have gold ring
          my gold ring is real gold i buy it
          • i dont know use this calculator
            • hahaha now i have fix my tgsl but i dont know working in outside or not
              but now is working find
              i change
              caps 15nf to 10nf
              sens pot 10k to 25k
              • Originally posted by paku View Post
                i change
                caps 15nf to 10nf
                sens pot 10k to 25k
                So bro do you have sound when you touch the box of TGSL??,how about deep same or ??
                • the deep is not same bro lost to much deep but all noise sound is gone
                  and very stable 1euro i got about 28cm
                  small gold ring about 25cm
                  • now problem noise again
                    need help how to
                    measure voltage
                    from
                    LM358
                    LM393
                    Lm308
                    LF353
                    All i see on schematic Pin 4 is 5v and pin 8 and 7 is 8v
                    • Null phase
                      U101 and gate or TR5
                      With lot of EM fields.
                      If I get metal close to coil it clears - sine wave.
                      Only coil shield (USB cable shield and coil shield - mylar) is on GND and one of two wires TX (from PCB)
                      • this is commercial detector
                        all will be silent with this project
                          You can try to find manual how to convert TGSL EDU to regular TGSL.
                          It has less amplification as I recall - so stable detector and probably same depth.
                          Looking for TGSL field test video - test coin bed.
                          Anyone ?
                          • Well reducing the 1meg in the first filters to 470k is a start.
                            The original had a small TX 8.X volts as I remember so adding
                            the FET stabilizer will tone the TX down.
                            These designs are sensitive to TX and RX changes. I'd recommend
                            building as per original schematics before doing any mods.
                            • I found some MAX667 LDO's that I'm going to use on my TGSL.
                              The big thing about these is they are adjustable! So I can run
                              the TGSL at 7v from a 9v battery! Nice!
                              http://www.maximintegrated.com/en/pr...rs/MAX667.html
                              The original 8v LDO I used was a 1.5 amp device and used 10ma by itself
                              this one is 20 microamps.
                              • Finished second DD coil for my second TGSL kit.
                                Standard 30 cm for 1 EURO coin indoors with sens at 3/4.
                                What can I change to gain more depth ?
                                RX and TX caps ... to adjust freq.
                                15 nF (it is 10nF now) and 22nF and 220 nF ?
                                RX 6.5mH 25.8 Ohm - tried to be on that value - extra few turns
                                TX 6.0mH 24.5 Ohm
