TESORO GOLDEN SABRE
    Hi everyone.. i been wondering if how many percent will be lost in the real ground compare in air test depth?
    Hi
    Depends whats in the ground iron /trash etc , that applies to any metal detector , Worth taking note that the TGSL are very sensitive to power lines etc , so much so that if your very close to a electric pylon it mutes the sound out as if its turned off.
    Built two of these in the very early days with different mods etc and both do the same.
    You need to be in the middle of no where, correctly ground balance the machine and it will perform ok.
    I still carry one of those in the van and quite often give it a blast if on site work or working at a customers farm.
    All the best
    Regards Dave
      @sdesic
      if you have problem while nulling big coils make it so:
      place the two coil so together that you have best null volltage (under 4mV is sometimes to low)
      if you ahve best result you can achieve glue you coil all 2cm with hot glue
      and set spacer between the gap
      the fill coil shell half with epoxi and let it harden
      next day measure the null voltage again
      if it has drifted take a very small pieces of foil and place it one one side of the coil and set the null voltage again with this smal pieces of foil
      if you found the best place glue it in and fill the rest of the epoxi
      @paku
      have you finished ?
      not yet bro
      i dont have time to make new coil
      busy working this is just hobby for more experience
      maybe i will do later
      • The floor of sensitivity does not, during the rotation of the potentiometer nothing happens, and the detection depth does not exceed 19 cm for a currency in bronze.
        • es that one of RX terminals must be connected to the shield?
          • Originally posted by ashefr10 View Post
            RX end and TX end must be connected to shield..
            • Originally posted by paku View Post
              what is big difference 2N2222, 2N2907 plastic one and metal one
              Paku, take attention: 2N2222 is NPN while 2N2907 is PNP.
              The metal one can dissipate heat better.
              • Originally posted by sdesic View Post
                You are artist - your detector is your canvas
                My 8V regulator is L7808CV
                Hi Sdesic,
                take attention: this regulator is not a low dropout therefore if you use it then it is better to have a 12V battery.
                • Originally posted by Sacchetti View Post
                  ok noted with thanks
                  do you have you tgsl video i want to see
                    I do not have built TGSL but only Eldo relative to tessoro md.
                    Before and after I have built others md with technology PI, BFO and PLL.
                    Can be I will do also TGS in the future, in this case I will propose my video.
                      what version eldo you make can you share
                        I have done the version 1265.
                        ATTACH]33191[/ATTACH]
                        But I think it is not correct to speak of Eldo because this is a thread relative to TGSL.
                        Therefore, please consider this answer only a parentheses.
                        It is better to ask info about Eldo in one of its threads.
                        • ok thanks
                          but this version is working ?
                          • hi who have sell TGSL Working Coil in here
                              ok thanks
                              The version 1265 is working as the others.
                              Can be was revised after but you can check it directly on russian website.
                              • Is it possible to discriminate bigger pieces of aluminium?
