TESORO GOLDEN SABRE
  • Rx coil connections, this is the best. I cant get it closer to 0.04 volts.
    • hello is how good the null of the coils as well? thanksClick image for larger version
      • I can replace the tl062 for TL082
        • Originally posted by nando.22 View Post
          Yes, also u can with tl072 or lm358.
          • 2N2222 can use plastic instead of metallic 2N2222A the change in operation
              You can used it! Its all the same!
                Yes but make sure you match the correct pins.
                • If u use plastic transistors, they need to be rotated for 180'.
                  • 2n2904 substituto
                      2n2904 substituto
                      http://www.geotech1.com/forums/showt...9880#post89880
                      • poblemas with tesoro golden saber only has a continuous sound anything detection
                        • hi-friends,,,I making finished tgsl edu,very good project,,this detector thick wave,,,I want thin sound,what do ı do compent ?
                          • Originally posted by kuzen View Post
                            Remove 2 (of 3) 1N4148 diodes from CD4024.
                            Pick any one of those 3 to keep, the one you like it most.
                            • thnx ivconic,I do. regards
                              • how to connect the coils
