TESORO GOLDEN SABRE
  • I also solder all parts in but use Sockets for the ICs. This is have I built the TGSL using Silverdog's PCB.
    The BEST info is concise form is Dan Bower's TGSL 101.pdf documents. Find, download and study.
    First is the TX Oscillator MUST run. Pull all ICs, except U108 (the 7808 regulator) and trouble shoot the oscillator (section 1 of the TGSL101 schematic). You may have wrong values components or have them mis-wired.
    After Oscillator is running at 14.5kHz the install the clock divider. This drives the DC-DC boost converter to get the -5V.
    Now continue installing ICs from RX through to audio ensuring each stage works.
    • Hello Majster!!!
      You must go step by step here in the forum is all the documentation about TGSL.
      You must go reviewing point by point and always verifying each component.
      The images of your PCB are not appreciated, reload it.
      I used 2907 but it wasn't with 2N, it was another code and I also tried with A708Y and it worked the same. At that time I couldn't get exactly the components on the list and had to adapt.
      • Hello again everyone,
        Thanks for the answers. The first thing I did was to carefully check the schematic and catalog description of 2N2907 and 2N2222. It saw, as I expected, that I have swapped CBE> EBC feet in both pairs of 2N. I have both BC547 correctly. I took out both 2N pairs and inserted them correctly. I tested the voltages and the generator / oscillator for both coils. I have a voltage of about + 8V and -7V. My coils have TX 14.2kHz and RX 13.6kHz, but when bending these values ​​change a little, which is okay. During the winding, I checked their inductances and they had the values ​​of exactly 6.0 and 6.5mH, they changed a little after binding, applying the screen and gluing. On the TX I have a voltage (AC) of 7.7V, which, as I understand it, gives an amplitude of almost 16V, which is also correct. The loudspeaker is silent, but I did not have both coils connected, only the TX. In the left IC sockets I have + 8V and -7V power supply, I assume that it is good.
        I know that the best documentation for TGSL was done by Don Bowers and Ivconic (eternal praise for them, and their teachers, their families, children, grandchildren and so on to the sixteenth generation), but this is documentation for professional electronics rather, and I'm just an amateur . The instructions I've read so far (and as you know, reading and following them are two different things) were something like this (for example):
        1. Solder elements 1, 2, 7 and circuit A, check the voltage on pins 4 and 7 in IC3 socket. It should be (something) V.
        2. Connect this and that, check the frequency on pin 3 of IC5, adjust to the value with potentiometer 2 (or other).
        3. Solder elements 6, 11 and 21, check something, etc.
        This manual is not like that. I miss the IC marking on the PCB (yes, there are their names, but there is more than one on the schematic diagram of similar elements). I miss the indication of control points on the PCB in this manual. They are in the diagram, but I miss a detailed explanation of what value to expect at which point on the PCB. Even this documentation mentions differences in two similar (but not identical) PCBs. I know that a professional electronics engineer can handle it, but my profession is far from electronics. But I also know that this is how a people learns: by reading, trying and making mistakes. When everything is going well from start to finish, you can't learn a lot. But I am very far from being criticized, because I know how much work the authors of the project and documentation put into it all. I'm impressed. This is very good documentation, I wouldn't even start without it. It was only reason that I decided to do with TGSL, and I considered the Russian Terminator 3 and several Polish VLF MD projects (also quite good), for which the documentation was weaker (although in my language).
        Loading photos doesn't work, I noticed it. I have a problem with this even though I am using the correct function.
        Regards Ruben2000, Waltr and everyone.
        • Everything you need to know about the TGSL is located here on Geotech -> TGSL - Complete Details
            And I did as I planned. I put all the ICs in the sockets. I connected the power and the loudspeaker. I connected the TX and RX and put both coils in makeshift form. At this stage, I was not fixing anything permanently. The coils are only lying slightly overlapping each other. I turned on the All metal mode, all 3 potentiometers at half scale. I turned on the power. I moved ferrite over the coils, a piece of steel, a piece of copper. Hear single or double beeps, copper seems to be giving a double signal. It is not very regular, the sensitivity is also not good (5-10cm), but I know this is just the beginning of the tuning and I cannot expect everything to be great at this stage. Then I moved a watch, a telephone, etc. over the coils. I can also hear signals, the sensitivity is better, but they are large objects. The coils sometimes go into some deeper resonance and the throbbing sound does not disappear when I take the items away. I can turn it off with the Diss knob, it's kind of weird. It can also be turned off by moving the coils apart.
            Then I switched to Diss mode and looked for positions where the ferrite would be rejected and the copper would not. So far I have not succeeded: it either rejects everything or nothing. But I know that the coils are only lying together, so it would be naive to expect them to work well right away.
            I understand these initial tests that the board is assembled correctly and all components are OK.
            To the island / position 7/IC101a I soldered the lead/cable for connecting the multimeter. I am going to look for the minimum AC voltage value between this point and ground now. But I think first I should bend the coils so that their inductances are closer to the values ​​of 6.0 and 6.5mH, what do you think? Once this is done I will attach the TX permanently in its semicircle to the base so that I can bend it a bit in diameter, what do you think? Then I plan to put RX on it and look for a position where the AC voltage of 7/IC101a / ground will be minimal. When it succeeds, I will have to fix the coils permanently and start tuning the potentiometers.
            Maybe you have any other suggestions?
            I must add that I wound the coils with 0.4mm wire, and their final resistance is slightly below 20 Ohm, I hope that is not a problem.
            The fun is in motion, I like it more and more
            I greet everyone.
            • Hi Qiaozhi,
              I have looked at these documents, I know them, although I do not understand all of them well, thank you.
              Greetings.
                As I wrote earlier, I bent the coils to have their inductances closer to the values of 6.0 and 6.5mH, it turned out to be equal. I didn't even have to massacre them somehow, all I needed was a simple gum rings and old, empty plastic pens. The frequencies of the coils were then about 14.3 and 14.0 kHz. A little bit of a difference, intuition tells me it should be a bit bigger. So far, I have not fixed the TX permanently because experience and intuition tell me that I will unstick it more than once. I was not wrong. I planned to apply TX and RX and look for a position where the voltage of 7/IC101a / ground would be minimal. But it didn't work. The AC voltage is almost constant 4.6 - 4.7V (1000 x higher than 5mV), with a frequency of 13.7kHz, regardless of the position of the coils. Maybe I solder something wrong after all? What could I have done wrong? Maybe you have any other suggestions? Maybe the board is not assembled correctly?
                I greet everyone.
                • Sounds like you got iy working. Swapping leads on the transistors is very common thing and great you found this. You are on your way.
                  The next Big step is TX to RX Coil nulling. This also really needs a two channel O'scope and is a very fiddly operation if you have never done it before. Do not rush and play with the null adjustment until you understand what it is doing.
                    These are the words of a wiser than me! I am pleased to read the words of encouragement, seriously!
                    Unfortunately, I do not have a real two-channel oscilloscope, but only a DIY sound card simple circuit. That's why I read so much about nuling by ear, or with the AC millivoltmeter. But having only what I have, I had to try anyway. I connected the circuit to this sound card, launched the SoundCard Scope soft and watched what I can see. This is by no means a decent oscilloscope, but I think (yes, unfortunately I can't be sure, I just think) I can see both waveforms and that they have a phase shift, but I can't tell if it's 20 degrees or anything. Sampling is too sparse / slow. But it's a good program anyway, the frequency values ​​of both coils it measures are the same when I measure them with an independent frequency meter. That is why I am trying with this AC millivoltmeter.
                    Overall it is like this:
                    1. The detector can see various pieces of metal, ferrite, copper, etc.
                    2. The sensitivity of this vision is poor (5-10cm).
                    3. The supply voltage (+/-) on the PCB is + 8.0V and -7.0V.
                    4. The diss mode is working similar, but I haven't nulled the coils yet, so there's no point in balancing the ground. To early for this.
                    5. The coils, depending on their position, sometimes oscillate longer, which is manifested by a pulsating sound.
                    Based on my observations, can I conclude that my PCB is OK? Is my problem only with the coils? Or differently: is it possible, being a layman, to make a PCB that works as described above (1..5), and yet it is not correct? I'm asking because it's my first VLF and I'm still learning.
                    I greet everyone.
                      I did this: I picked up the RX coil and turned it over, then reassembled both DD coils. Again, I was looking for a setting in which the voltage between the indicated measurement point (pin 7 IC101 / ground) would be minimal. Unfortunately, nothing changes, I still have 4.6 - 4.7V AC. I'm beginning to suspect that the problem is on the PCB after all, but what could it be? I checked all the elements and connections 3 times, I have no idea. Maybe someone else has an idea?
                      I greet everyone.
                      • I try to add photos of my work:
Name:	TGSL Elements 2 .jpg
                        It's working So, now the rest:
Name:	TGSL PCB Soldering.jpg
Name:	TGSL Coils.jpg
                        • Disconnect the TX coil and measure IC101-7, see if the problem goes away. If it does, you have an imbalanced coil. If it does not, you have a different problem.
                          Keep in mind that ordinary multimeters are designed to measure AC at 50 or 60 Hz, not 14kHz. Building metal detector circuits really requires an oscope.
                          • Use VA software (visual analyzer). It has oscilloscope.
                            Sound card scope is limited, however by using VA there is a trick.
                            Open VA and go into settings/ scope. Click boxes designated Channel A full D/A and Channel B full D/A. Now your waveforms should be smooth.
                            • In addition to Carl's and Dbanner's suggestions.
                              Coil null only happens within a very small physical range. So move one coil very, very little at a time to look for the null. The null will happen only within a few millimeters and best null within a fraction of a millimeter.
                              First time trying to null the coils is very hard but will be easier once you know how.
                              • I balanced my the coil with ordinary multimeter. I didn't care about the reading the meter was putting out, I new it would be bandwidth limited. What l looked to see was the dip in voltage as l moved across the null. I just aimed for the lowest reading. So I knew that this was closest to where I needed to be. Then I began adjusting the gb trim for ferrite reject ( just on the edge of where ferrite is barely clicking). Then I wave various coins and metals to check discrimination range. All this time I am ever so slightly adjusting coil, gb trimmer and so on. Repeating until it is best.
                                Keep in mind that the tx frequency should be nailed down at 14.5khz( or was it 14.9khz, I don't quite recall)
                                Don't bend or deform the coils( you should glue in the tx coil so it can't move. Shift the entire RX coil left or right across the tx coil.
                                Don't bend or deform coil. When everything is to satisfaction, glue in place. The RX coil should be tuned to resonance at 16.1khz( if I can remember) this is important so phases and gb trimmer can be adjusted properly.
                                That's how I did it. No oscilloscope. I think I kept the meter connected while shifting around to get a feel for where I was in relation to the null point.
                                The trick is that so long as you can eliminate ferrite within the range of the gb trimmer while getting proper discrimination and good distance, then you can be assured that you've got close to the 21degrees phase balance required for the tgsl search coil since this performance could not be achieved otherwise. It is deductive logic.
