TESORO GOLDEN SABRE
  • Originally posted by Ruben2000 View Post
    Hello Walt!!
    I used this American coin.
    I am going to get myself a multi-turn potentiometer for the GB, I notice that it is necessary to be able to regulate it with more precision.
    Thank you very much for your advice!!!
    Yes, that US 1 cent is copper.
    Originally posted by mostafalesnar91 View Post
    Where is from my friend?
    Please would both of you add at least which country you are in to your Profile.
      Ok, amigo!!
        How do I install this bf245c on this circuit? I do not trust the datasheet and it is very difficult to detect the gate, source and drain with a multimeter
          • SGD or GSD ?????????
            • Originally posted by mostafalesnar91 View Post
              [ATTACH]57102[/ATTACH]
              [ATTACH]57103[/ATTACH]
              I would trust the data sheet and give it a try.
              DS shows pin order as GSD in the orientation of the JFET in your picture.
              Other way is to actively test. Look up "Testing N-ch JFET" on the web for how to do this.
                Okay! It is really difficult for an electronic engineer to have trouble recognizing MOSFET bases, I am a self-taught person !!
                But I already installed one of these bf245c in the original TGSL, so GSD is right !!
                Now I installed it in TGSL Edu like this, I think that's right !!
                Do you confirm this ???
                • I'm sorry I can't upload pic
                    Does anyone see anything wrong ??
                    [ATTACH]57046[/ATTACH]
                    [ATTACH]57047[/ATTACH]
                    I installed like this!!
                    that's right?
                    • If you now know that the pin order is GSD then the schematic of the TGSL will tell you how to install it.
                      • You should install BF245A or BF245B.
                        I install 2N4393.
                        • thanks
                          • my tgsl edu air test!!
                            with weak results
                            maybe I didn't adjust the device properly or my loop didn't null properly!!!
                            how do I measure frequency???https://m.youtube.com/watch?v=3axhGgCzqVE
                            • You are swinging objects incorrectly. Watch other videos on YouTube on how to do hand movements correctly.
                              • Originally posted by ArchibaldSTM View Post
                                no difference!!!!
