OK, who knows the peak voltage on the left and right channels at the headphone out at no load? While you are there check with a known load.
Nautilus peak output voltage?
Naulilus
I called Steve Garris about 2 years ago. He told me one channel was 18 volts with 150 ohm series resistor, the other was 12 volts 47 ohm. Both at worst case 50% duty!
That seems to be quite loud. I wonder what a real test would measure. That would burn out quite a few headphone volume controls on a lot of brands.
