Help me identify transistor
  • Help me identify transistor
    Hi @ all. help me identify this transistor i think it IC is marked A6W58 but i cant find any information about it. Im pretty shure it's a transistor cos there is several like this IC on the board.. Thanks
    try to analyze with a DMM for P-N-P junctions like reverse/forward junctons, then try to check with oscilloscope using low power supplies, then try to replace with a good transistor, the number need not be same u can replace with any general purpose transistor depending on oscilloscope trace....
    U seem to be confused with the words "...... it's a transistor cos there is several like this IC...."
    If u post the picture of it its good, someone can help u. try to debug the waveforms at the transistor with transistor on the working board
      A6WBAS16PhiC SOT23High Speed Diode BAW62 (1N414
      Diode NOT transistor.
        thanks }]:
        http://www.tkb-4u.com/code/smdcode/smdcodeA.php
        i found interesting site with smd markings
