GP3500 Query
  • GP3500 Query
    Hello everybody,
    This question is going to be a bit basic to most of you here but i am trying to learn more about the workings of the GP3500 Minelab Detector.
    I am new to all this so i am not up with all the tech talk as such so basic answers would be very helpful.
    On my GP3500 there is the Socket that the Search Coil cable connects to & it has 5 Pins numbered 1 through 5 in an anticlockwise manner as shown below.
    1 5
    2 4
    3
    My question is which of these pins is the transmit voltage pins & which are the signal reciever pins if i have the terminology correct or anything correct.
    Also when tested with a multimeter what should the Voltage be at each pin?
    Is one pin the Earth--Ground pin or is the Earth the outer Socket itself Earthed onto the main case.
    My other question is:
    These detectors are Dual Voltage so do they send say a 6 volt spike with one pulse & then say a 3 volt spike in the next pulse or how exactly does this work.
    Any help would be greatly appreciated.
    Thank You
    Can anyone help??
      The GP series detectors transmit one large and 3 small pulses,the supply to the large pulse is a regulated 5 volts and the supply to the 3 small pulses is
      a regulated 15 volts and they call this DUAL VOLTAGE TECHNOLOGY.
      Zed...
