DAFISGOLD3
  • DAFISGOLD3
    THE TEST IS ONE
    WWW.dafisgold.gr
    Oπα Μιχαλη αρχισες και διαφημιση .....Εκτος συνόρων ???
      καλημέρα στην Λάρισα
        Καλημερα φιλε
          Hi. who is the depth from magnetometer sensor and who is the depth with the big square coil.
          As i know when you made the test, at the discrimination mode the detector lose about the half depth. So it is a detector only for "all metal" locating.
          It seems like Superscan by Eric Foster
            Yes my friend George It seems like Superscan(by Eric Foster).....
              Hi. In the discretionary function of the p.i. detector Geo Leave depth
                Τακη τι εννοεις???
                  Τακη τι εννοεις???
                  Λεει οτι αμα θες διαχορισμο,ξεχνα το βαθος.(Τα αγγλικα του ειναι )
                    Hi everyone
                    Our detector when in metal seperation mode looses only 30% of its depth. It can detect a piece of coper 20x30cm in 2 meters. Dafis Gold 3 has nothing to do with Superscan, see attached images. I would like to thanks spiros who attended the tests we made for Dafis Gold3
                      Hi.
                      maybe have some diference from Superscan, but this is not the problem because superscan is a very good PI detector for big objects.
                      You did not answered me about magnetometer sensor depth. When i saw the test by rospy i did not saw any magnetometer head. Is it FGM-3 or proton???
                        Dear Geo,
                        We dont use magnometer head (FGM-3 or Proton). The FGM-3 works with different frequencies 10khz-120khz. Dafis Gold 3 is a pulse detector, with a pulse up to 420Hz thats why it provides such a large depth. If you are interest about technical details get your car and come over here to check it out. We invited you at the test sessions but you didnt come which is better than seating in front of a pc and making questions.
                        Sorry for my english,
                        kind regards,
                        michalis
                          χαχαχαχα.....Καλα να παθεις Γιωργο.Δεν φτανει που αλλο τον ρωτησες αλλο απανταει,σε βαζει και χερι οτι σε καλεσε και δεν ηρθες στη δοκιμη,και οτι καθεσε σε μια καρεκλα πισω απο ενα pc και κανεις ερωτησεις.........
                          ΕΕΕΕΕΕΕΕΕεεεεεε Νταφι λιγο σεβασμος...Ο Geo δεν ειναι κανενας τυχαιος..
                          .....Ειναι Guru ο ανθρωπος στο σπορ,ΚΑΙ ΟΧΙ ΜΟΝΟ.
                            Originally posted by MICAL64 View Post
                            Dear Geo,
                            kind regards,
                            michalis
                            Hi Mical64.
                            Perhaps i did not understand so well, so explain me...
                            at your site, on English page you write...
                            "The Dafis Gold 3 is totally new high technology pulse-induction detector with discrimination DIR (deep iron reject) - combination of Metal Detector and Magnetometer Sensor System, one of the best professional pulse induction metal detectors in existence. Dafis Gold 3 is designed for detecting deeply buried or lost metal objects, treasures and similar objects".
                            So what is the Magnetometer Sensor System, what are you mean.
                            And why at page for Greeks you dont write nothing as this????
                            I don't remember when you called me to see your test???? please answer me. I am sure that you did not like me to test your detector because there are a lot of other tests that should become, not only to see at who distance it locate a piece of coper
