Easy Detector
    Hi! Friday! Have you tried the coil? What are the impressions? Do you need to make a 1.9mH inductance coil or....???
      CS 550 Minidisc is a TR locator! It has a frequency of 100kHz. So if you make a coil of 6mH then you should put like 500pf capacitor.
      I checked it really is a TR locator, Not a VLF!
        I checked, it really is a TR locator, Not a VLF!
        I guess original coils of cscope have like 1.9mH inductance because when you add 47nf capacitor,parallel, you get 16842 KHz which is roughly 17Khz.
        Uf! And I thought it was easy detector....
          OK! Here is the deal! This is a nice detector to make! Problem is coil! Just use your imagination and make a coil good enough to oscillate at 100khz. I changed a few transistors and can say that it works on a test coil. Disc and sens are mounted to fit in a small box along with one 9v PP3 battery. Sound is strong and stabile also.
          Here is the lay file. enjoy!!!
            Hi. From this link, you can get the manuala and a field test report in .pdf format.
            http://www.csmetaldetectors.com/archive.aspx
            Nelson
              Coil
              Hello Kuraja,
              Thanks for the pcb !
              Can you make a coil that works at 17kHz-19kHz,( tune with caps) test this coil on your pcb ? ( for me it works ok)
              Start with 50-50 TR windings and 100 receive windings 0.25 mm and searscoil diameter 20 cm.
              I think the minidisc is 17-19 kHz !?? Have you checkt the 100kHz on a original working detecor ?
              Best Regards.
              Ap
                OK! I will try that but I am out of wire now (been making those TGSL coilz), but I promise I will test it with 17khz and 100khz!
                  Hello Kuraja,
                  Are you sure about your lay file?
                  i.e: On 4024 circuit pin 8 ( must be 7 ) and also capacitor 100uF the positif is in the wrong way, there is also other difference on circuit.
                  Can yoi check? It looks strange.
                  Best regards
                  Luc
                    Hi luc!
                    This is corrected version.
                      Hi luc!
                      Many thanks Kuraja.
                      Luc
                        Hello, I'm interested in this proyecto.me like to build, but corrected the pcb is not clear where to connect the center of the coil is rx-tx but the center?. I do not see where to connect the favor if altavoz.por You have more information about this project ponedlo.un greeting
                          CS550
                            Your posting doesn't make sense. Why don't you go through it and make sure it says what you mean to say, before posting?
                              easy detector
                              hola,debe ser por una mala traducción de google traductor.lo que quiero decir es que en la version corregida solo veo dos puntos para conectar la bobina,rx-tx.¿tengo que conectar el centro de la bobina a tierra?la bobina terminada debe tener 3 conexiones mas pantalla,100 espiras con toma central a la 50ª y construir un escudo en la bobina tambien conectado a tierra.¿estoi en lo cierto? gracias,un saludo
                                Try Babel Fish @ altavista
                                hello, it must be by a bad translation of google translator which I mean is that in the corrected version I only see two points to connect the coil, rx-tx. I must connect the center of the coil to earth? the finished coil must have 3 connections but screen, 100 turns with central taking to 50ª and construct a shield in the coil also connected to earth. estoi in the certain thing? thanks, a greeting
