Garrett A.D.S. VLF/TR deepseeker with bad sound output???
  • #46
    Master Hunter 7X, same problem, no sound
    Hey guys, I just joined the forum. Awesome. I like forums like this. I recently fixed my washer by using a forum with a good tech member. Saved me probably $200. Sweet.
    I've got an old 1990 Master Hunter 7X Crossfire by Garrett. Same problem - NO SOUND! It worked fine the last time I used it 2 years ago. Put 6 fresh new batteries in too.
    I called Garrett and they would NOT give me the schematic to my unit! Told me to call back tomorrow when a tech named Ed Renner (SP?) was in.
    I see Conan fixed his ADS (a little older than mine I think?) and it was the MC14011 IC circuit. Mine has a "14011B X933" 14 point circuit. I'm GUESSING that's the same/similar one? Please note: I have done NO testing and wouldn't even know how or where to start! Electronics moron here - but with potential! I see Big Daddy has a "IC 4011" but I don't know if that's the correct cross-referenced part. http://bigdaddy-enterprises.com/index.htm They have no contacts that I see. My next problem even if I get the part is replacing it. What am I getting into? Think I'd better get someone to do that for me.
    P.S. - I noticed that my same model sold at a goodwill auction for $213 recently in 2011. Can't believe it went for that much. That's almost what i paid over 20 years ago. Is this thing a collector's item now??
    • #47
      Best to start a New Thread on this.
      Things don't get all mixed up.
      There are other test you should do before Pulling IC's.
      I would start with the battery compartment.
      Start a New Thread!
      • #48
        "Best to start a new thread". Will do. Thanks!
        • #49
          Please help find a manual
          I have same VLF/TR Deepseeker detector as pictured here but I have no idea how to use it. Do you have a PDF of the manual? I tried to get into Garrets but page is not active. Hope you can help. Thanks
          Alex
          • #50
            Do you have a DPF manual of this detector?
            Originally posted by Gold dredger View Post
            Ok here is the pics This is the Master Hunter ADS deepseeker model.
            I have just same detector but have no idea how to use it and Garret page is not working or does not let me get in. Hope you can help me with a PDF of manual. Thank you
            • #51
              Alex
              maybe you need to ask Sven... seems he is knew them well...
              http://www.findmall.com/read.php?56,...89#msg-1482489
              • #52
                GARRETT DEEPSEEKER MANUAL
                Hello Alexcheve
                Here is the manual for the Deepseeker ADS hope this will help you
                getting started with a bit of practice you should be O.K
                Try on the automatic first,because is more stable (if it works properly)
                Cheers
                • #53
                  About coil to arm connector
                  Thanks for the manual! one important question I missed before is about what can I use to attach coil to arm as the detector I bough at a garage sale has no screw there. Can I use an ordinary metal screw? Or does it need to be plastic or aluminium? Can be loose? Hope you can help here too
                  • #54
                    GARRETT COIL MOUNT TO SHAFT
                    Hello once again Alexcheve
                    If you can get a nylon bolt all the better,but original ones are made
                    of metal anyway.Since they are placed in the neutral detecting part
                    of the coil,the center.Regarding how tight,just enough to hold the coil
                    at a comfortable angle for you to detect.Hand tight but not loose.
                    Get a metal bolt with a small butterfly nut on it.So you can hand tighten
                    when you need to.But never overtightened.They are easily available from
                    Garretts spare parts or any hardware store.Just take the coil with you
                    to try the different sizes to get the diameter right,so it's not loose.
                    Hope this helps
                    • #55
                      what a relief!
                      Thanks for the info, I will go buy it right away
                      • #56
                        Alex, by looking at your pic, your detector isn't the same as mine.
                        • #57
                          turn on the switch, and disconnect the coil and connect immediately...
                          • #58
                            Hi everyone, I need the wiring diagram for the Garrett Ads 3. Thanks
                            • #59
                              You only need to post your request once in the forum, not multiple times in multiple topics.
                              I have removed your other 3 identical posts.
                              • #60
                                ok thanks, but could someone help me? Thank you
