TGSL Tuning & troubleshooting
    I think what may be the problem for sdesic is that the Silver Dog schematic has an extra-high gain amplifier compared to standard TGSL. That can make instabilities more likely, even involving local EMI noise.
    Maybe someone has already suggested this, but assuming the circuit is built correctly (in spite of the puzzling TR4 gate signal phase), I would recommend the following:
    1. Change feedback resistors R29 and R31 from 1 Meg to 470K. If that is difficult, consider piggy-backing an additional 1 Meg resistor in parallel with each resistor on the circuit board (avoids unsoldering).
    2. Replace capacitors C14a,b and C17a,b with single 4.7u bipolar capacitors. If bipolar are difficult to obtain, use back-to-back 10u capacitors, carefully observing the polarity in the schematic.
    This will slightly reduce the gain and increase the center frequency of the filter section, same as the standard TGSL. It should be a more stable MD.
    3. Take the circuit and coils outside, far away from power lines and computers. Use an AC voltmeter to null the coils by minimizing the AC voltage at LF353 pin 7. Maybe choose point slightly on either side of minimum.
    Let us know if it still beeps.
    Normal alkaline batteries should be fine -- you shouldn't need big lead-acid batteries.
    I must do this next ... how about that -6V I measured on LM358 U103a (pin 5 and 7) ? It that OK ?
    1. is OK
    2. don't have bipolar - will try to find two the same 10uF 25V
    3. when I finish first two
    Alcaline are fine but I am going to have belt with batteries ... so no problem with weight
    less weight to swing arround
    • Originally posted by sdesic View Post
      porkluvr,
      in my last post with graphs is TR4 vs TR5
      www.geotech1.com/forums/showthread.php?16122-TGSL-Tuning-amp-troubleshooting&p=173608#post173608
      audiocard scope does this kind of graph...
      I am going to have scope for use this next week so I can do another
      it is one channel oscilloscope
      Those gate signals look like severely anemic. But, they are consistent and I am unsure about the capability of your scope. Maybe what I should have asked more directly is: (in DISC mode) how does either gate signal look in a side-by-side comparison to the signal at CD4024-1?
      • porkluvr,
        I have made screenshots of Disc mode TR4 and TR5 separately vs pin1 4024 (green on both)
          No, that is not OK at all -- very wrong -- but first make sure you are measuring the correct pins on the correct IC chip. It is easy to get mixed up.
          The voltage should be between - 1 V and 1 V. Typically about -.2 V for example.
          If you are sure the voltage is -6V, then look for some kind of short to the negative rail, maybe a solder bridge or bad capacitor C12 for example.
            Simon,
            I will gave scope in this week so we can check it again...
            one channel only
            One channel scope is almost useless for most metal detector troubleshooting, since phase relationship between signals is so important to many functions. But it will tell us the shape of signals, which can be useful to see distortions.
            If the scope has an external sync probe, it can be used for phase, but with great difficulty.
            • all metal mode - while beeping
              DC voltage on LM358 (pin 3) 1.075V
              DC voltage on LM358 (pin 1) 1.076V
              same IC lower side
              DC voltage on LM358 (pin 5) -5.90V
              DC voltage on LM358 (pin 7) -5.99V
              I will check for solder bridge ... this kind of PCB prevents almost all bridges... except inside of IC socket and soldering on IC sockets
              • I have that same -5 to -6V on LM393 pin 7 and all pins of TR5
                on LM393 pin5 is 0V
                  on LM393 pin5 is 0V
                  Ok, we have found a problem there. Time to start looking for reasons.
                  • removed 15pF capacitor connecting to disc switch
                    and 220nF C12
                    I have detection but very low ... no beeping ... I think it is not ceramic 15p
                      and 220nF C12
                      and 220nF C12
                      When making a circuit change, keep checking those voltages that were wrong so we make sure you fix the problem.
                      >> I was wrong with this so edited: [I would check C12 for short circuit. Then look for solder bridges. Then suspect bad chip or part.]
                      I don't think a bad C11 (15pF) would drag down TR5 or the LM393 pin 7 to -6V.
                      Actually, I'm wrong about checking C12 -- that would not make a -6V measurement (no harm in checking anyway -- remove power, short the capacitor with a wire, then use ohm meter for rough test).
                      1. Problem could be negative power supply getting in somewhere. Possibly solder bridge, or bad LM358.
                      2. But another possibility is if your coils are not nulled and you have a very large null signal at LF353 pin 7 (16 V p-p for example) and your phase is such that the ground channel is in sync with negative going RX cycle, you might get a large negative voltage on C12 and pin 5 of U103a, as you observed.
                      3. Can you measure the voltage at LF353 pin 7 and show it on same scale as TX signal so we can see how large it is?
                      4. Also, you can put your voltmeter on C12 or pin 5 of U103a (LM358 ) and then null your coils and see if you can make the voltage near zero?
                      • placed back ceramic capacitor 15pF and it still do not beep
                        I have tried maximum sens and no beeps or other bad sounds
                        detects on 2-3 cm
                        I have to replace that 220nF capacitor and then we will see
                        nulling will be fine I think
                        • replaced 220nF with other one and that -6V comes back
                          • >When making a circuit change, keep checking those voltages that were wrong so we make sure you fix the problem.
                            OK, removed again C12 220nF and now measuring
                            on 393 U102 pin 7 -3V
                            on 358 U103 pin 1 is now -6V
                            pin 3 is now -6V
                            pin 5 is now -2.7V
                            pin 7 is now -2.7V
                            replaced with another but I have that -6V on pin7 I removed it ...
                            OK
                            it is not C12 that is short circuit
                            • I could swap IC 393 and IC 358 with another on board so we know are they or not bad
                                Good idea -- are they in sockets?
