TGSL Tuning & troubleshooting
  • Some coins are mild steel with a nickel coat.
    So at the final op amp filter output the ..
    Nickel is trying to push a positive signal - which if nickel alone would "ping"
    Iron is trying to push a negative signal - which if Iron alone may give a "clip" sound - rejected"
    In this special case the Plus from the Nickel and the minus from the Iron - - these sum to zero and the comparator does not get tripped and you dont hear anything. Ive had that with these designs.
    S
    • Simon,
      I will do some testing and experimenting as I now have working TGSL EDU thanks to you and all others who helped.
      I don't have coil placed in epoxy yet but I will try it in field and experiment with GB.
      Lot's of variants to try.
      It is far better than I had week ago with my Surf Pi Pro and digging every shrapnel and peace of metal that it found.
      I must look for bulgarian coil "enclosure" thing. Epoxy. Stem. Battery holder, XLR 4 pin ...
      1. I think I have two so I will reverse RX connections
      2. will try 10nF again
      3. mylar is my shielding - emergency blanket
      4. allways can try other USB cable... better - thicker
      5. ground on connector to box (now wires)
      In all metal mode ...
      Coin is hand
      Silver US quarter 1964. and before 90% silver 10% copper
      • I replaced original 15nF capacitor parallel to RX to 10nF polyester film
        reversed wires on RX coil (I had double beeps)
        GB trimmer is set to less value (40%) to reject ferrite ring 3 cm
        I then loose silver US quarter and clad quarter and aluminium coin ...
        can someone explain why?
        it can detect small silver coin 1.7cm (92.5%) but can't detect bigger silver 30g about 3.5 cm
        detects old silver coin (83.5%)2.5 cm
        all this in all metal mode
        can I ignore GB settings and move on ?
        • Originally posted by sdesic View Post
          Try ground balancing with a ferrite slug instead of the ferrite ring. The shape of the ferrite ring allows it to sustain eddy currents for too long, with the result that your GB point is not in the correct position.
          You can retrieve the ferrite slug from a tunable inductor, as shown above. Then glue it onto the end of a length of wooden doweling to make yourself a tuning wand.
          • what size ?
            • Just about any size will do. I have a little bag of various cores, rings included, and it is quite handy for waving. It is good not to get too close to coil though. TGSL and such tend to saturate.
                what size ?
                As Davor said, the size is not critical. The one I often use is 10mm long with a 5mm diameter, although one half of a large pot core is OK. I've used both. As long as its not a ring, since it then tends to look like a lump of iron.
                • Found two of those trimmers for induction from radio equipment - taken out screw (ferrite). They are 5mm long 3mm thick. Tried to eliminate them with GB trimmer and did (one of them is taped on to wooden stick). But it is same thing with aluminium and silver
                  (on stick also so I don't touch them - only one tiny beep when I bring them on to coil)
                  It is better if I turn coin sideways to coil then goes beep but close to coils.
                  Tried one more ferrite ring broken in half it is about same ... it can be rejected 10 cm away but if I bring it closer to coil it beeps again
                  both rejection loose silver quarter and regular quarter 1970 and other silvers and other silver coins are recognised.
                  I have also found that if I use ferrite stick 3-4 cm long it can be found if I wave it facing coils strait sides,
                  and when I turn 90 degrees if vanishes or breaks (sound is broken)... same air depth
                  • experimented with RX coil wire (upper one on PCB) connected with GND or SHIELD
                    and it works for silver and aluminium and clad US quarter
                    small silver is not lost
                    Bigger ferrite can be found still or if I get close to coil
                    • dont get too hung up on the ferrite thing its a guide
                      If you dont have much mineralisation in your local soil it will still work
                      S
                        S
                        Moving on, thank you.
                        Must field test this detector so I will know.
                        • Hello,
                          I have a doubt:
                          Where are create the -5V ?
                          I think it is where I draw a circle but I don't shure ?!
                          Scuse my so Frenchy English :-)
                          • Hi telome exact it is this stage that make this voltage condition that you will plug your coil or no tension.
                            slt telome exact c'est bien cet étage qui fabriquent cette tension à condition que tu y branches ta bobine sinon pas de tension .
                            • Many thanks friend !
                              Merci beaucoup l'ami ! HI (je comprend bien l'anglais mais je peine un petit peu à m'exprimer, à cause de mon manque de vocabulaire)
                              • TGSL EDU i buy from silverdog kit need help on my voltage on TX i get 6.56v on RX i just got 0.56v what is the problem
