Garret Freedom 2 help needed.
  • Garret Freedom 2 help needed.
    Hi all.
    I have here,an Garret Freedom 2 that needs sorting.
    I've just got a 12" coil for it. When turned on with the coil connected.disc 1 and 2,the thresold is a little crackly and it wont detect a large coin until it's nearly touching the coil. But it's not much better in all metal. But with a large item of say 2" x 3",it gives a lot stronger signal in all metal. But not so clever in disc modes. It cant seem to see the smaller items very good.
    All controls seem to work ok.
    Any ideas folks
    Here is the following coil wire colours etc
    COIL------------------- MACHINE
    Pin 1 = Earth---------- Pin 1 = Green
    Pin 2 = Black---------- Pin 2 = Yellow
    Pin 3 = Red------------ Pin 3 = Blue
    Pin 4 = White--------- Pin 4 = Pink
    Pin 5 = Green --------- Pin 5 = Empty
    The coil is the Garrett Crossfire 12" for the GTA/CX etc.
    Not the Crossfire 2 for the GTAX etc
    I would have thought this coil is correct for the Freedom 2 ?
    It detects large items at good depth at distance in all metal,but struggles in disc.
    Plus i have read somewhere that the ACE coils will work on these machines. Have anyone else heard this please.
