Which PI detector, is better?
  • Which PI detector, is better?
    Hi there,
    please guide me to select best PI detector to build...
    i want more depth and better performance...
    White's Surf PI Pro is better or Delta pulse or other one?
    thanks...
    Originally posted by GOLDENSKULL View Post
    Hi there,
    thanks...
    THESE DETECTORS ONLY SUITABLE FOR LEARNING ON PI
      well, thus you offer which PI is better for building???
        Did i can detect one 0.5*0.5 meter metal object, with 1*1 meter search coil in 2-3 meter depth, by White's Surf PI Pro or Delta pulse or other one?
          anyone can answer:
            Delta Pulse at all times
            I suggest to you the delta pulse detector.I think is the best pi detector delta pulse
              Delta pulse is good (deep) detector, but its power consumption is too high for my taste.
                is there any other idea?
                  Why you need PI if you have your L-Rod which can detect anything at at least 2 kilometers with accurate discrimination?
                    Perhaps he's seen the light.
                    The Surf PI is really designed for beach hunting.
                    Why don't you build Hammerhead? There's all the information you need, plus a good quality PCB can be obtained from Silverdog for an inexpensive price.
                      Hi Qiaozhi,
                      yes i have own L-Rod,,,
                      i want one powerful pi for exact pinpionting...
                      which pi is better for this...
                      i put on this forum soon my L-Rod action film for proof it...
                      Have fun...
                        anyone can answer:
                        1. for coins, jewelry on beaches - Surf PI, Hammerhead (BTW it is one schematic).
                        2. for big objects like coca cola pot, rifle, artillery shell, air bomb, tank, car - Delta Pulse.
                        3. for big objects also may use moded Surf PI and HH.
                        good luck
                          Hi GOLDENSKULL
                          My delta pulse , with coil 40 cm , can detect 1 euro from 40 cm on air . !!
                          But important point for goldenskull , if you trust to your Lrods , and can find long buried metals
                          From long distance , you must be don’t use PI type detectors , only VLF .
                          For VLF , you can build sascho best vlf detector , my built can detect 1 euro coin with OO
                          Coil , diameter 19 cm from 40-45 cm on air by meter .
                          Also Tesoro golden sabre also good ( I am thanking from Qiaozhi , ivconic , max ) , my built can detect 1euro coin from 35- 40 cm
                            thanks dear aft_72005,
                            waiting for my L-Rod film very very sooooooooooooooooooooon
