IGSL
  • I returned from the hospital after the infarction and immediately to the computer ... Thank you very much for the tips. Last time I forgot to put the sensor photo, with the data that I wrote before the imbalance was 40 mv. I'll try with Тх-14,5кгц, and Рх 16.12 kHz ... I really like the voice of the goals! I'll still finish it !!!Click image for larger version
    • guys
      again and again i reminder you. again and again. both shieldings must NOT be touched together one-to-one.
      another way you get ELECTRIC ring closed EMI field. SPLIT THEM by izolation.
      do not do me angry guys. do not do.
      • The coils are isolated from each other by transparent tape! Well, the output of the shields of the coils, naturally, is soldered to the screen of the cable, but how else?
        • Tx is 14.5kHz and Rx is 16.12kHz.-
          made a coil with such frequencies, the metal detector works very badly! It may be necessary on the contrary-the frequency Rx should be less than the frequency Tx ???
          • I believe F-75 coil is about the best choice for future IGSL projects. It is balanced at 13kHz.
            I'll seek a cost-effective way to obtain such a coil, first and foremost for another project, but I'd like some experimenting with it. If someone may whisper a good word on my behalf at NEL, I'll appreciate it. My funds are running low.
              guys
              Correct! You need extra vertically and horizontally EM-field shielding at best with
              AFC auto gain level adjustment to filter out the best possible signal-noise ratio!
              https://en.wikipedia.org/wiki/Balun
              This stuff meanwhile even all the new smartphone WiFi chips have inbuilt.
              • Data of the MD F-75 sensor, right Click image for larger version
                • Originally posted by nikko10 View Post
                  Data of the MD F-75 sensor, right [ATTACH]43653[/ATTACH]
                  That's the closest I could get as well. To me it seem to be the sweet spot. Frequency, Tx inductance, Rx/Tx inductance ratio, Rx resistance... everything is just right.
                  • I'm confused (something that happens quite often). In the schematic shown in post #2167 both the Tx and Rx coils are labeled 12.9031kHz. Does this mean that with tuning capacitors connected across them both coils are tuned to the same frequency? As I understand it this gives better sensitivity but unreliable phase response, which affects ground balance and discrimination.
                    • Originally posted by Gwil View Post
                      I think they were both tuned at same frequency in order to measure(calculate) the precise inductances and induced voltage in the Rx coil at null in full(equal) resonance of both coils, thus giving full parameters of the search head with cable and connector, but applied to use in device IGSL, would be tuned "off resonance"
                      Just my guess.
                      • Thanks, that makes sense. Now I'm wondering what the coils are tuned to when they're plugged into the detector. Does anyone know?
                        • I do
                          Tx is resonant at 13kHz, but in F75 it is supplied via a kind of bandpass configuration to enable single-ended drive and soften the resonance. That way it is driven by a digital source, and frequencies are chosen via menu to avoid interference. Also the coil voltage is considerably higher than could be possible by direct drive.
                          Rx is softly resonant at over 20kHz. In that regard this configuration is quite classic. The only twist is a serial RC connected parallel to the coil, and its function is softening the resonance bump.
                          Of course, driving this coil this way is not the only possibility. It should work just fine in "Musketeer IGSL" Tx. Or the drive could be produced by a quartz oscillator and a counter. Say, 420kHz ceramic resonator and CD4060 counter/oscillator. This coil is used by a detector still in production, so this is a good choice regarding availability for many years to come.
                          • That's excellent, many thanks. As you say, a good choice to be used with a home built detector and also looks like a good design to be copied by people who enjoy winding their own.
                            • Good afternoon! I collected the IGSL device, the range by air for coins: 1kop.-20cm; 2kop.-25cm; five inches of Catherine 2-32 cm, the signal is clear high-pitched, I cut the colored metal with the regulator, the black channel remains twisted, for some reason it is voiced low in tone, like black metal. It's still unclear, this metal detector does not see black metal of small metal ??? I offer ordinary pliers-see see at 5-7, somehow not that ... In the photo the blue sinusoid-Tx, somewhere 16, 17 volts, the yellow sinusoid of 1 foot of the chip U1, somewhere 800 mv.
                              Instead of LF347, I supplied LMC6484.Developers of GB black and non-ferrous metals to exhibit before their clipping, to small clicks. Thanks for an answer in advance
                              Да,забыл написать:Тх-374нан,Rx-15нан
                              Перевод с русского на английский-УЖАСНЫЙ,извините ,друзья.Спасибо огромное за помощь моему другу из Чехии -Hyena
ID:	352104There is an error in the layout of LM339 ??? The black metal channel does not work, maybe this is the reason ???
