Tesoro Tejon
  • Tesoro Tejon
    Dear friend
    I need some help please.
    yesterday i recieved my second hand tesoro tejon,
    the perfomance similar to musketeer advantage abit less,
    i have 10cm firet rod i i tested but doesnt reject it at all no matter
    ground balance setting even 15cm above the coil still very loud sound.
    another thing is ground balance volume so loss but it works .
    i thought it should be deeper than musketeer advantage but
    its not any help will be appriciated
    at first open the box and make good quality makrophotos from every detail and post or link them
    then look here
    http://www.tesoro.com/info/manuals/current/tejon/
    sorry cant give you more help
      Originally posted by metaldetector107 View Post
      Dear friend
      If you cannot achieve ground balance with a ferrite rod, then it is highly likely there is an internal ground balance setting that needs to be tweaked. I had the same problem with a Tesoro Bandido.
        Tesoro Tejon is a very stable machine, and setting the country is done as follows, treshold to turn the unit ,the hardware that provides permanent auditory threshold and podixemo up and down the country sound trshodla is disturbed when the probe up and down the country At one point, when the country was rejected trsholda sound remains the same and in the construction and the the probe descent from country if the above will probably be tuning in bad hit,All the above is true for ferrite rod ,with Tejonom I had the opportunity to do just now very nice work, and there is no problem for the affected countries which I myself was convinced today and previous days working with this machine.Best regards Orbit.
          and podixemo //and raise ,Sorry for the bad English translation.
            The Tejon was the most sensitive detector I ever had(http://www.njminerals.org/metaldetecting-deepcoins.html).
            You need to learn to use it before attempting to " repair " it. every detector has its quirks. the tejon has more so than others.
            I wish I had my old notes to help you, but I don't.
