IDX-PRO+VDI
  • its ok about the vdi i just want it to be complete when finished. anyone who did finish the vdi what setting for the oscillator 4 , 8 , or 10 mhz is the reset used as a reset and should the watch dog timer and brown out both be off?
    • All fuse settings are included in .hex file.
      Oscillator mode is INTIO2 (PIC16F88 ) or INTOSCIO (PIC16F690).
      Reset is internally tied to Vdd, reset pin is an input.
      The watch dog timer and brown out both are off.
      • I noticed that SilverDog uses METALIZED Caps for his IDX PRO Kit.
        Can these Caps be replaced by POLYPROPYLENE Caps without quality loss ?
        • Holyuser thank you very much I just don't yet know much about the whole programming process but I am learning and I just wanted to not mess this up thanks again very much. when I have stuff ready I will show pictures.
          • Hi jlsilicon
            "Metallised" and "Polypropylene" refer to two different aspects of capacitor construction. A capacitor consists internally of two conducting layers separated by a dielectric (insulating) layer. The dielectric layer can be a plastic such as polyester, polystyrene, or polypropylene, or any one of a number of other materials such as ceramic or mica. In capacitors using plastic film as the dielectric the conducting layers can be either metal foil or a thin layer of metal deposited directly onto the film, in a process known as metallisation. There are no hard and fast rules, although usually polyester capacitors are metallised and polystyrene use foil. A capacitor simply described as "metallised" will almost certainly be polyester. Polypropylene types can be metallised or foil - in low power/low voltage situations such as the guts of a metal detector, either is OK. Polypropylene caps have somewhat superior properties to polyester so can be used without a problem, assuming they physically fit on the pcb OK. (Wikipedia has entries on capacitors in general and film caps in particular.)
            Hope this helps.
            Gwil
            • Yes,
              thanks.
              • Well, I tried using Polyurethane instead of Epoxy for the Coil.
                But, its flexible like stiff rubber - like tire rubber.
                So, I would not suggest using Polyurethane as a solution for the Coil.
                To fix this, I will am going back over it with Epoxy to solidify it.
                • polyester resin is very hard, fast and cheap. Often used on glass fibre
                  eg
                  http://www.halfords.com/motoring/pai...as-resin-250ml
                  fill in stages, as volume cure gets too hot
                  • I get better results with epoxy. Can take several days to fully harden this cold weather so once semi cured I but it in the oven at 50C goes rock hard.
                    Polyester also works and is cheaper but not as hard and I find the null alters as it cures
                    Both make usable coils.
                    • okay !
                      Finally realized what was causing the random chirping in my Metal Detector;
                      - I used an Automated Buzzer instead of a Piezo.
                      So any strong DC would create a Buzz, not an Oscillation.
                      Stupid mistake.
                      Fixed.
                      • My guess is that this Buzzer was also feeding back and creating the VDI noise ...
                        • put it back on and have a look
                          • Have not tried since I got back from Europe this summer (had to dissassemble it before I left there - to skip customs worries).
                            I had built it in europe this past year.
                            Trying to reassemble it.
                            Not much spare time.
                            No BUZZ yet.
                            • ok i got my boards from silverdog they are great smaller than i was expecting so thats a bonus. just if anyone knows how the wiring for power goes if you could help a bit you would save me some time. it looks like there is a switch wired to the board but it says p5 also theres a pot in the front called p5 so iam wondering is that pot a 100k with a switch if it is i still cant tell how all the holes near the power works. i don't know if you have pass me a hint please.
                              • I have this;
Name:	IDX PRO quick connect_finalvdi.JPG
                                I think you could use a pot with a switch on it for Sens. Silverdog even
                                sells some (which I got for mine).
