AD8532
  • AD8532
    AD8532, not so easy to find in local shops.
    I was searching the net to find closest substitutions.
    Various MAX's etc..etc..
    Also tough to obtain.
    Wandering if there is some closer opamp that can be easily obtained?
    Hello,
    May be here, or extend the search, following your location :
    http://cgi.ebay.fr/AD8532AR-SMD-Integrated-Circuit-x-1-pieces-AD8532-/400225129286?pt=UK_BOI_Electrical_Components_Suppl ies_ET&hash=item5d2f46d346
      AD8532 difficult to find
      I think I may have found the reason they are difficult to find, they have been discontinued, see the .pdf, which gives lead free equivalents, probably in SMD.
      If you need the original version you need to find those companies that specialize in components that are not produced anymore....
      I hope this helps.
      Andy
        Only the non-ROHS version was discontinued.
        iv, what feature of the 8532 did you need? High current drive?
          Dear Carl,
          may I ask what the comment you made added to the document I posted? or my comment?
          Waiting on your explanation....
          Have a great day
          Andy
            Current generator stage/drive, YUP!
            Single supply, rail to rail, dual package....
              Originally posted by der_fisherman View Post
              Dear Carl,
              Have a great day
              Andy
              You seemed to suggest the AD8532 was discontinued, but only the non-RoHS package was. I was just clarifying.
                ROHS Compliancy for this Chip
                I was suggesting that the version he was looking for was discontinued and may be the reason he was having problems.
                I attached the notice for that reason. In that it was clearly detailed what was discontinued, what is still available..
                It was also clearly detailed in that document that replacements would in a different package..... one that is ROHS compliant (with regard to certain poisons for example).
                I did not see a reason to repeat the details in the attachment again, once should be enough for anyone, don't you agree?...
                What I wrote was:-
                What I think happened was that I don't think that you really understood what I wrote (speed reading), nor did you read the attachment before posting.....that would explain everything.
                Been there and done it myself, its easily done!!
                Have a great day.
                Andy
                  Der fisherman,
                  at lest; do you allow Carl to answer me and give me directions, related to my question?
                    If you click here, there is a supplier in Croatia that has ROHS compatible and the non ROHS compatible versions for sale:-
                    http://www.analog.com/en/audiovideo-...inventory.html
                    I hope that helps.
                    Andy
