PIM-2 DELTA DIGITAL NEW
  • PIM-2 DELTA DIGITAL NEW
    http://www.lugatek.com/forum/index.php?topic=150.0
    Link above apparently not working. Interesting project, another MCU based variation on delta/XR71, is .hex code available?
    BTW, Did anyone on this forum tried to build PIM-1? I made PCB for it and programmed MCU, but unfortunately, time is relativistic...Any practical experience whit that machine?
      The link works ok for me ... although I can't understand a word of what's posted there.
        It appears to be in Turkish
          I know that!
          But I still cannot understand it.
            What Google translator say:
            Hello Friends.
            I did the design of this detector, a digital version of the classic Delta Pulse'nin. New name, PIM-2.
            -Analog circuitry is fully owned by Delta Pulse'ye.
            Delta Pulse'deki-556, 4538 and 555 integrated circuit made of two tasks are now engaged in the Atmega8 microcontroller.
            -Built-in 2x16 character LCD Module
            All settings can be made-Üzerideki device with four buttons.
            Choice of two languages-English and Turkish
            Watching the screen data:
            Battery Voltage: voltage of your battery. Turkish language option with 'P', in English, with 'B' listed.
            Threshold: the threshold indicates the value you've set. Turkish language option 'E:' and, in English the 'T' is indicated by.
            Signal Strength: metal and metal on the severity level of the received signal indicate that it is made of Tune. Turkish and English modes, 'S' unless otherwise indicated.
            Fading Curve: Pulse Induction Metal detectors based on the slope of the curve in this region to watch the fading, a little can get an idea about the type of metal.
            Adjustable parameters:
            1 - Power: is set between 1-10. Power ayarıdır.Normal value is 10.
            2 - Delay: 0-10 is set to. The normal value is 0.
            3 - The Earth: is set between 1-10. Noral value is 5.
            4 - Threshold: 0 - 20 set. Normal value is 0.
            5 - Language: Turkish and English language contain two.
            __________________________________________________ ___________________
            PIM-2 Preparation for Use:
            1 - Connect the device and the search coil voltage is supplied. The device will be set automatically at startup and will be ready for use. That's it ...
            PIM-2 Settings:
            - The device on the main screen when you press the ESC button, such as Delta Pulse'deki can tune the process.
            - The device while the Up and Down buttons on the main screen you can enter the menu by pressing the Threshold setting.
            - Enter the menu by pressing the Set button. Using the Up and Down buttons to set the parameter you want to bring.
            - For the parameter you want to adjust the value using the SET button and the Up Down buttons to move to a desired number
            - Vaz, if you want to move to the button you can press the Esc. After setting the value of the upper menu by pressing the Set button, and then come to the main screen by pressing the Esc button.
            - Adjustable parameters try to stay as close to the values ​​indicated in the title. Turn off the power to change the offset adjustment to any setting.
            * Built-in settings when powered off the device thanks to kaybetmeyecektir eprom.
            Commissioning of the notes and tips:
            1R 5W resistor resistance value RX stone. If you are commissioning an external circuit is used in glass fuse, fuse connected in series.
            PIM-2, I recommend to use the speakerphone if you can find around 16ohms.
            Ayıramadım too much time on the PCB drawing. For this reason, rather than the number of hops. Smiley Do not say no if that draws a better PCB
            Appendix;
            PCB'si-PIM-2 in PDF format
            On-PIM-2 scheme in PDF format
            -PIM-2 Floor Plan PDF
            -Hex format codes for the ATmega8 mikrodenetleyicisine
            -Hex format of the data are located eepromuna ATmega8 Microcontroller.
            This is the first message, attaching all relevant documents to fully edit and friends temporarily locking this topic.
              Hi to all
              PIM-1 and PIM-2 are my design. PIM-2 is digital version of Delta Pulse.
              I am preparing documents. I will share PIM-2 with you.
              Follow:
                Hi again
                You can obtain all documents at following link.
                Good luck
                  pim-2 test video
                  http://www.youtube.com/watch?v=yNe90ml9aTk
                    pim1 is fully free out now
                      how can i disbale the 200times on off limitation of PIC16F877
                      is it possible to lock the eeprom? and how
                      The circuit can be turned on 200 times. After 200 you need to re-install the program on the PIC.
                        another solution can be to read eeprom, find the code for the Limitation and set it to max Counter, so that detector can be used several years without re-programming. this works also for lugatek vdi limitation
