More on two-box, CA3035, etc.
    Airport Security Metal Detectors
    Does any one know what technology is used on Airport Security Metal Detectors.
    A friend of mine said that this kind of metal detectors are the same used by two box MD.
    If this is rigth, please let me know if is posible to make a two box metal detector from an old Airport Security Metal Detector, because i have some circuits access.
    Nelson
      Sure!
      Hi Nelson,
      Well now it depends on which brand of
      walkythrough detector you are talking about.
      some have xmit and receiver coils in both sides.
      these will not work with side panels.
      others which are pulse induction will have
      xmit on one side and rec on the other.
      So you would have a GIANT two box.
      Of course with all of these, little concern
      was spent on the design as to power consumption
      as they were plugged into the wall.
      Even the few portable units the lead acid
      battery would be half a car battery.
        Most are PI.
          Sounds noisey to me
          Hi Chemelec,
          Hmmmm,,, you will need some form of
          filtering or you should expect alot of
          noise. In fact to improve the performance of
          many detectors is in the reduction of noise.
          Without a doubt there could be phase shift.
          Not important if not "trying" to discriminate.
          If you are "trying" to discriminate then I would
          still recommend some form of filtering to enjoy
          the benefits of the performance, and still
          perform the demodulation correctly.
          One technique might be to Null the coil
          slightly in the direction of sending a small
          xmit phase signal through and using this
          as the reference for the zero and ninety degree
          demod, i.e. amplify this signal, square it up
          and use for reference.
          there might be even better ways than this to
          accomplish this.
          Certainly the best design would be one which makes
          any component drift with temp unimportant in an
          area of higher Q, sharp selective filters...
          But oh the performance.
          like in radios, which are wide enough to
          pass the modulation.
          only in this case no modulation so can be very
          narrow. of the oscillator needs to be somewhat stable
          or once again "track" so this error falls out.
            Yes, Carl
            Hi Carl,
            Yes all are PI or Earth Mag now
            one is vlf. some of the PI pulse from
            one side and then the other which
            I guess would still work for two box.
            This is really sillly.
              Improvement?
              Hi Chemelec,
              Someone did say improvement
              didn't they? oh well maybe not.
              Hey filterpro doen't do bandpass filters.
              I fired it up and looked. I use other
              things which cost money so had forgoten
              still could make 2nd order highpass and
              then 2nd order lowpass is another option.
              and hey if the phase shift bothers you
              just open up the passband until you feel
              comfortable. Or you can build what has
              been built before and if you get it all
              right it will perform the way it performed
              before.
                Originally posted by JC1 View Post
                Hi Chemelec,
                before.
                One object of the 2 box detector system is to have both the recieve and transmit coils Resonant at Exactially the SAME Frequency.
                This Tuned Resonant signal Far Outways any Noise.
                But with a good power supply and a good Layout, the noise in my circuit is not a problem. But Without a Good Layout, Oscillations Will be a problem.
                  Twob MD with an airport security MD
                  HI JC1, and thanks to everyone that reply to me.
                  Well, i ll call a friend of mine to get the hole circuit and started to study it if i can make a two box with it.
                  I also don´t know the brand of this MD, but when i get the details i ll share it with you.
                  Nelson
                  Hi Nelson,
                    Two box with PI technology????
                    Carl.
                    So if most of airports MD are PI, i can understand that if i make a two box with this technology i ll have a two box pulse induction metal detector...humm... is this ok???... if so, i can figure out, that will not discriminate, but it will go very deep.
                    Nelson
                    Nelson[/QUOTE]
                      Carl.
                      Nelson
                      Nelson
                      [/quote]
                      You can build a "2Box type" PI detector BUT Really it will be a PI with 2 coils AND the coils must be parallel between them. But if you want a 2Box detector make a reall 2box. At this forum you will find shematics of white TM808 or GeminiII.Another good solution is to construct the Buccaneer IB detector with 2 coils as 2box. I tried it before years and it worked Very good
                        Right
                        Nelson,
                        Geo is correct.
                          Two box MD
                          Ok, thanks for all the information.
                          Nelson
