Carl,
Can you help me on the best way to construct a bigger coil for a White's gold master series. I have opened up the stock concentric coil and have done alot of measurements. I have measured the inductance,capacitance, ohms and hopefully figured out the impedance. White's sales two different size concentric coils and a DD coil for this series of metal detector. I would like to build a 16" to 20" DD coil. Some where in that range. I have found that the coil has a resistor and two parallel caps in parallel with the two Tx coils. The coils are in series with each other. Also the Rx coil has a big difference in inductance and resistance because of the windings. It has no passive electronic parts in series or parallel. If any it is in the control box. What is the best way to attack the solution to contruct such a coil? Any help would be appreicated. Rick S
