TL9401 Voltage to Frequency chip
  • TL9401 Voltage to Frequency chip
    Hi guys
    I'm a tinkerer with little electronics training...mostly hobbyist kit-building etc. So I could use some help on a chip I want to use for a detector mod.
    I am using the TL9401 voltage to frequency converter.
    I want its max input to be from 0-2v and output to be 1KHz max range. Also I want to use a 9v battery to supply it.
    http://pdf1.alldatasheet.com/datashe...OM/TC9401.html
    (FIGURE 5)
    I wouldn't know where to start with altering the sample schematic or if the desired outcome is possible. I could use some help.
    This isn't the only chip I could use...its the one I have. So if something better suited for my needs I will go with it.
    Ran
    Upon further investigation the LM331 would be better suited to my needs. I will work with that chip and post my mod in the proper forum when finished.
