Vaquero tuning
  • Vaquero tuning
    Dears,
    after my last success story with my Lobo ST I will need continue, it is clear.
    So, first, I did catch any very nice short instruction video for quick set up Vaquero (or Cibola in MOD) to 3 GB modes in the same time... POS/NEG/NEUTRAL
    It is done through Freq shift switch, and it is working well.
    http://www.youtube.com/watch?v=bhTtkGCisfQ&feature=player_embedded#!
    And first set of question:
    My main interest is: DO YOU HAVE ANY info which trimmer is important for change factory preset mode from permanent POS (in disk mode) to NEG mode? I am looking for picture of control board and indexing right trimmer. It can be the same for all Freq?
    So, do not hesitate support this discussion, and if we will have lucky, I will posted back result, be sure.
    Thanks, regards
    litrfree
    Glad you liked my video!
    I thought that the greatest benefit would be for the unmodded Cibola. If you have changing ground conditions and don't want to mod your C, you can set you internal pot to neutral GB while in freq2, then you can adjust more neg or pos by using freq1,3.
    I also discovered that freq1 has the strongest inductive field, so I'm guessing it also has the greatest depth. I have yet to test that guess.
