Best detector for ...
    Originally posted by Freelander View Post
    I'am optimistic now, thanks to you dear.
    I found this two version:
    Sniffer xr71p 100Hz
    Sniffer xr71, 400Hz
    may be there are the same generally, but Witch the best?
    kindly,
    From the same seller?
    Tell seller your needs and ask how each version suit to it.
      Two nicknames, the both from Bulgaria.
      I'am with the seller here:
      http://www.geotech1.com/forums/showt...715#post153715
      Our friend explain that is " just a little fast response"
      Many thanks,
        does the delta pulse is good for gold (3-4meter)??? if not plz recommend detector to make at home
          To go that deep you would need a big coil, no?
            Good, if you are searching for gold plate as big as 1x1m.
              very thanks for reply
              so which one is better for gold hunting?
              pim2 (lugatek) pulse star 3,2 (teknoloji ekibi) or modified classic delta pulse?
                What sort of gold? Tiny nuggets, bigger nuggets, gold coins, gold cache, gold vein, small golden statue, bigger golden statue? It is not all gold the same from detecting point of view. But in general better (more adaptive to your goals) PI are those with more (timing) controls.
                  i search for jar's of old gold coins,
                  if im not wrong just delta pulse classic and pulse star 2 have timing control
