Anybody read German please ?
  • Anybody read German please ?
    Hi all
    does anybody read german , I am trying to program a ATmega8
    google translates the words to this but is it correct ?
    thanks
    6666
    From Google translate
    So everything stays the same, the AD converter
    set to AVCC.
    Fusebits see AVR Studio.
    Brown-out detection level at VCC = 4.0 V
    Brown-out detection enabled
    Ext-Crystal / resonator medium Freq.Start time 16K CK +64 ms
    The fuse bits are ATMega8/16MHz.
    It should be the same type as used in this
    I have the software for 16MHz and 2.5V internal reference AD
    have planned.
    Original text
    Damit alles beim Alten bleibt wurde der AD-Wandler
    auf AVCC gesetzt.
    Fusebits siehe AVR-Studio.
    Brown-out detection level at VCC=4,0V
    Ext- Crystal/Resonator Medium Freq.Start time 16K CK+64ms
    Diese Fusebits sind für ATMega8/16MHz.
    Es sollte gleich dieser Typ eingesetzt werden da
    ich die Software noch für 16MHz und AD-Referenz intern 2.5V
    geplant habe.
    Hi all
    thanks
    6666
    set to AVCC.
    have planned.
    Original text
    auf AVCC gesetzt.
    geplant habe.
    i try to help...i know some German:
    (Damit alles beim Alten bleibt wurde der AD-Wandler
    auf AVCC gesetzt)
    Dammit,everything remains the same, The AD converter setted at AVCC
    Fusebits sees AVR-Studio
    These Fusebits are for ATMega8/16MHz
    It should be the same type, as used in this one
    geplant habe
    i still have to make the software for 16MHz and AD-Reference of 2.5V
    the rest is good
    hope it helps a bit
    Marius
      hello
      Original text
      auf AVCC gesetzt.
      So that everything remains the ADC was
      set to AVCC.
      Fusebits see AVR-Studio
      this Fusebits are for ATMega8/16 MHz.
      geplant habe.
      it should be placed the same type at once because i have planned the software still for 16mhz and the ad reference internally at 2,5V
        Thanks for your combined help
        you never know if google translate gets the words correct
        cheers
