deeper as Pirate black-devil, or as good
  • #76
    Originally posted by lasser View Post
    I do not want to tell you what changes I made,if I do this I would steal the idea Nasko,
    and if we continue to spite you, I will show you anything
    I thought this site we can help each other,but it seems you it is despite
    Please learn better english or use other translation software -
    because you don't understand it.
    Just asked what are now the results of your improvements!
    I don't care to know what you have modified electronically.
    Again, lasser, LISTEN:
    What do you want to find with the better detector?
    What purpose?! Can't you answer this simple question?
    There is no "despite". You should work constructive with us here
    and don't misunderstand everything all the time.
    And you must tell in the first place that you want to know
    what detector is better because for modifying it, too.
    And we have to know how good the Pirate Black-Devil really
    works, because if it works bad, every detector could be better!
    • #77
      I really gentle on what she wants ,tried three detectors and for the year thinks he knows everything! detector such as whites idx in air test can be done 1 euro to detect to 60 cm by 24 cm with probe and still be perfectly stable,but nothing does not mean secondary mineralized ,ground !much time should be ,to acquire some sort of knowledge it takes time ,So if you have time ,You explain that he still but he will always ask you the same question when one knows little about something He will be a lot of time needed to understand to actually does not know anything!!!
      • #78
        Really?
        And what MD can detect 1 Euro coin at 70cm ???
        • #79
          -i think you and Orbit speak abaut white idx pro TURBO modified by Bill with texas electronics agreement and sell it only in germany .i read abaut it.goes to a 1 euro coin more then 50 cm.but its not a stock idx.
          -Funfinder you mod. 1266 i think which is a legend .congratulation.
          • #80
            thx for the additional info & congrats, scarface.
            Last week I was out with the moded Fisher 1266-X and it still
            works the same good as 20 years ago and even better now.
            Let's see if lasser will continue writing here -
            because alot of such guys just like to get their help
            and if it's not their taste they suddenly vanish into thin air...
            • #81
              I try not to put my mind to fool like you,
              smart as you think but when I asked an MD to head out deeper as a currency mine you had no idea
              honestly you shake like a stupid for anything
              • #82
                I want an MD for coins and small objects
                • #83
                  pirate
                  -we try to improve performance of this pirate black devil -hope you like this new video.we use the 32 cm. coil and i think it works nice.
                  http://www.youtube.com/watch?v=f2Tkv2AtE48
                  • #84
                    Awesome video. Very good job.
                    • #85
                      Hi lasser,
                      please don't misunderstand me and don't create unjustified trouble.
                      We have to work together so everyone gets better treasure hunting results or technical information.
                      Otherwise this forum is obsolete anyway. Technical informations and no assumptions, rumors and everything watering (diluting) opinion-smalltalk.
                      OK, fine, now we know you wanna hunt for small stuff.
                      In this case you really should find a detector with 15-20cm coil
                      or you modify the coil of the Pirate Black-Devil / create own one.
                      Thank you for the video clip. It looks fine but under real conditions
                      you either have to hunt extremly slow, carefully and while listening to the slightest changes and at low mineralized sites.
                      And even if you do so you will lose 75% of sensitivity.
                      Your video is fine but you will not recognise those "borderline"-signals under real conditions.
                      The best test is if you go for a real treasure hunt and check out:
                      what is the depth and size of those finds that you will get with a weak signal.
                      I don't know if it is possible with the Black-Devil but you may shift/mod the motion-circuit into direction of non-motion and add a reset-button!
                      And of course now I can tell you what detector may deeper for small stuff as the Black Devil:
                      As example a Pulse Induction with small coil! Can you modify PI?
                      Do you need discrimination?
                      • #86
                        hello admin
                        i want to buy a gold detector which can find underground treasures in maximum 10 meter.
                        where can put this question with more details?
                        please help me
                        • #87
                          Originally posted by mehdi789 View Post
                          hello admin
                          please help me
                          I presume you're referring to a long range locator. If so, then please read this first ->
                          http://www.geotech1.com/cgi-bin/page...&file=main.dat
                          We do not discuss LRLs here in the Geotech forum. To do that, you will need to register at www.longrangelocators.com
