Voltage reg
  • Voltage reg
    i need plans for a regulator that will turn 12 volts into 7.2..also a safety just incase the regulator packs up and sends 12 volts frying my circuit...if some one could help...need it to be easy to make and as cheap as possible
    thanks
    rod
    Re: Voltage reg
    How much current? How good a regulation? You can do something grungy with an opamp, zener, and a couple of resistors.
      Re: Voltage reg
      DC current about 2amps and yes it has to have good reulation
        Re: Voltage reg
        2 amps... that's a lot. You need to drop 5 volts, thus the series device(s) needs to dissipate 10 watts. So you will probably need a heat sink. I can sketch up a basic regulator that will work fairly well, might have to wait til I get back home where I have a scanner.
          Re: Voltage reg
          THANKS CARL
            Try this...
            Here is a simple circuit that will do what you want. The opamp should be a single supply type like the LM358. The transistor should be a high-power type, TO220 case with a heat sink. The 2-ohm resistor is optional and should be a wire-wound 10 watt rated - it will reduce the power dissipated by the transistor and should provide short-circuit protection if the transistor goes south. The 240-ohm resistor can be made with (2) 120-ohm resistors.
            What are you wanting to do, run a cordless drill off of a cigarette lighter?
              Re: Try this...
              I should not speak up considering the mistakes I have made recently, but I get 6.2 v out.
              Robert
                Re: Try this...
                Oops... you're right. The 120-ohm resistor should be 440-ohms, made with (2) 220-ohms in series. Thanks!
                  Oops again...
                  I meant the 240-ohm resistor should be 440... need more sleep...
