Frankensaw! Its alive!!!
  • Frankensaw! Its alive!!!
    I have been busy in my laboratory er...I mean my shop building a horizontal bandsaw to trim coil shells once they have been vacuum formed. This saw has 24 inches of open blade, probably net 22 inches once I add the blade guide bearings. I flipped the switch tonight and frankensaw roared to life!
    I machined all the bearing blocks on the mill out of 5/8 aluminum, as well as the wheels and most of the hardwood parts. Thats 6 quarter tropical mahogany beams (they are brutes) with a double 1x8 oak backbone. A bit overkill it turns out. Next up will be the table top, stand, and plenty of finger proofing for safety.
    If this works well for trimming shells I may replace the hardwood parts over time with aluminum.
    You must have a good wife
    You do very good work,my wife will not let me have that much fun.
    I need to build a work shop so I can have that kind of fun............
    I like what you are making.
    NICE
      Dangerous
      Hello Charles , good work with your saw band , but it is very important to put a shell protection over the saw band , because sometimes the band broke and if you are near around, the saw can you hurt very bad , ok , dangerous design without badsaw protection ...
      You make great shell Charles ,felicitation, nice work ,have good works,
      Alexis.
        Oh believe me the saw will be fully encased, I don't need 8 feet of bandsaw blade flying around the shop!
