Hello i have a question have anybody the dimesions (Wide angle an so on) for a normal detector stem the best with a picture thank you .excuse my english im German
Detector stem Dimension
hello from berlin
i think you will get no other question like that
there is no standard stem
if you want build your own use some plastice pipe and bend it with a hot air gun
to the angle you want and best fits to yout arm dimensions
if you want to put it in you back pack then modify it so that the longest part fits in there and want build together it is lng enough for you body
Originally posted by Vermeer111 View PostNo my Question was the Dimensions for standart stems (Fisher Whites and so) with a Picture (or a Painting) with dimensions Angle and so on thank you
Hi Vermeer ,
So etwas ?
I've copied it somewhere from Geotech , can't remember who posted it for sure ( -SB ? )
kind regards ,
Dennis the Mennis
