Here is a new technology MANTAMETALDETECTORS.COM
BI - MAGNETIC - COIL TECHNOLOGY
This will avoid the deposits of patents, I published here and elsewhere ....
I also filed in France.
This 2 coils are wound together for maximum coupling !
The first in one direction and the other in the opposite direction.
First coil sends and receives the second coil flyback
Second coil send only and receivesthe first coil flyback (but is not analysed)
The two coils have the resonance that armonise.
The second mosfet cut through its diode...
With a very good coil I can start at 6us delay (with a very good shield)
With this system I start at 9µs ..(with a very good shield) It's nice !
First pulse 1 = + V + GROUND EFFECT (g)
then pulse 2 = - V + GROUND EFFECT (g)
reception was Pulse 1 rx = + V + s or "s" is ground effect
then Pulse 2 rx = + -V + s
then by (pulse 1 - pulse 2) it gives + V + V + g - g = + 2V and "g" has disappeared !!
The system works perfectly and does not alter the analysis when compared with a single coil!
The electronic components in this schematic are not well on the components used on my product.
This system is better than US9285496B1 Patent of CARL / Less capacitance, lower noise, best heat dissipation, faster delays, etc ....
Alexandre
Alexandre
